Same place as the 2008. MarvCan anyone tell me where the Gasoline fuel filter is located for a 2012 cadillac cts sedan with a 3.0 lt engine thank you in advance
Well, Vram DID answer the question. :rimshot:chas1 comes out of his burrow once a year, not unlike Phil (and he didn't even try to screw up a weather prediction) and you guys are so helpful. :stirpot:
Step 1I give up....Can anyone tell me where the fuel filter is located on a 2008 CTS 3.6 DI?
You are confused. Our fuel filters are integral with the pump and located in the tank.Step 1
Locate the Cadillac CTS fuel filter underneath the passenger side of the vehicle, just in front of the rear tire.
Step 2
Open the vehicles gas cap to relieve the pressure in the fuel line and then reattach the cap.
Step 3
Lift the car up with a floor jack near the right rear tire and slide a jack stand under the axle near the tire.
Step 4
Lower the vehicle down so that it is resting on the jack stand and place a gas can underneath the fuel filter to catch any gas leaking from the lines.
Step 5
Slide the quick-connect fitting on the gas tank side of the fuel filter back and pull the fuel line away from the filter by hand, placing the end of the fuel line in the gas can to catch any leaking fuel.
Step 6
Detach the threaded fittings on the engine side of the fuel line from the fuel filter with an open-end wrench.
Step 7
Remove the fuel filter from the fuel line and place the end of the fuel line into the gas can to catch any excess fuel.
Take the gas can out from under the CTS and remove the old fuel filter.
Items you will need
- Jack stand
- Gas can
- Open end wrench
What year CTS are these ^^^^ instructions for?
NO external fuel filter on a 2nd gen CTS.
Right where that information belongs.Prob for first gen, my 04 CTS-V had a fuel filter in that location
So the filter is part of the fuel pump or down in the tank somewhere??Its in the fuel tank like all new vehicles. The fuel system has been changed to a returnless system and the filter will last until the pump goes bad.
All GM vehicles, 2003 was the last year of external fuel filters.The trucks went to this type back in 2004 and its not been a problem.
Do gas stations have fuel filters?So the filter is part of the fuel pump or down in the tank somewhere??
Check this out.Do gas stations have fuel filters?
All gas pumps at US gas stations have filters somewhere in the line. You don't have to worry about it. The filters on the pumps will catch any sediment.
