1 - 10 of 10 Posts
2006 CTS
I have a 2006 CTS V6. I need front brake pads. What type pads came from the factory, ceramic or semi-metallic? I'm looking at the Wagner Pads at Advance. They have either ceramic or semi-metallic at the same price.
John
2006 CTS
Thanks for the info. Would you recommend the ceramics or the semi-metallic?
Both sites were helpful.
Thanks again,
John
CTS
Thanks again,
John
I will be changing mine in the next month, and I'll be using ceramics. I have the FE5/JE5 package, and the top brake site above has POWERSTOP Z-16 CERAMIC's for $51 an axle.
$100 for all four wheels, when the local dealer wanted to charge me $250 for the rears, none ceramic.
I have satisfied pro ceramic pads all around....great pads stop amazing ,,,,also have drilled n slotted
2004 CTS
Actually, OEM is ceramic. At my shop we would use Monroe part# MBK CX921
They come with clips and ships to help avoid squeeks. Also, make sure you measure then cut the rotors, otherwise they will eventually squeek.
-Josh
CTS 3.6 2005
What is the diff between Sport suspention and Base model ? Rotor Size ?
How do I differentiate the two models ??
The sport is a little thicker rotors I have heard..if you buy new ones just put the sport ones on, they are the same calapers, just a stronger rotor. Not much thicker and should be the same price.
1 - 10 of 10 Posts
