Unfortunately, I don't think there is one. From the manual:
Shifting Out of Park
This vehicle is equipped with an electronic shift lock release system. The shift lock release is designed to:
• Prevent ignition key removal unless the shift lever is in P (Park) with the shift lever button fully released, for vehicles with key access.
• Prevent movement of the shift lever out of
P (Park), unless the ignition is in ON/RUN or ACC/ACCESSORY and the brake pedal is applied.
The shift lock release is always functional except in the case of an uncharged or low voltage (less than 9 volt) battery.
If the vehicle has an uncharged battery or a battery with low voltage, try charging or jump starting the battery. See Jump Starting on page 5-48 for more information.
To shift out of P (Park) use the following:
1. Apply the brake pedal.
2. Then press the shift lever button.
3. Move the shift lever to the desired position.
If you still are unable to shift out of P (Park):
Fully release the shift lever button.
While holding down the brake pedal, press the shift lever button again.
If you still cannot move the shift lever from P (Park), consult your dealer/retailer or a professional towing service.
