How long does a new center support bearing on the drive shaft last. Is it an easy part that gets worn out fast?
2011 CTS Coupe FE3, 2003 Thunderbird, Gone 2013 ATS, 02 Deville
The bearing should last for many years. There are many things that could cause the bearing to wear out sooner than normal.
2015 ATS luxury (2.0T w/6MT), 2006 CTS sport
It's 2-3 hour job that can be done in the driveway, if you're the DIY type. Mine lasted about 160,000kms before needing to be placed (rust belt car though)
2005 Base CTS work at Pullen solenoids Glass Factory for 36 and a half years
How many miles are on your vehicle and where are you located? There's a couple of other things that you might consider replacing at the same time that will make support and your differential bushings last longer.
Roy
