It looks like 19 inch CT6 wheels might fit on a CT5, the offset is only a few millimeters more. Has anybody done this, or seen it done? I still need a second set of wheels for my original summer tires, after buying all-season tires in December and this might be an option.
'05 CTS-V
What are all the specs for each? In which direction is the offset different?
From memory...
CT5 19" x 8.5", 120 mm bolt circle, 29 mm offset
CT6 19" x 8.5", 120 mm bolt circle, 33 mm offset
'05 CTS-V
4mm isn't much, they would probably be just fine. Is the center bore of the wheels the same?
You could also get some 3mm spacers and end up basically the same as stock. Would have to check thread engagements on the wheel studs, but they'd probably be OK - on most cars 3mm is about as much as you can run.
