CT4-V Intake >> ATS-V
1 reading
4.4K views 6 replies 6 participants last post by  TwinTurboFan
#1 · (Edited)
From what I've been able to gather, it looks like the CT4-V intake is better than the ATS-V intake. If I had to guess, the ATS-V intake was conventionally located on the front corner because the early ATS-V development models included an LT4 engine. For the CT4-V, engineers were run through a gauntlet to reduce power losses, and the dual symmetrical plumbing is what they came up with. It's right out of the ATS-VR program.
I've been going cross-eyed looking at pictures of the engines and support structure, and I'm pretty sure that all the CT4-V parts can be transferred from to the ATS-V. I've been able to locate most of it:
1. CT4-V vs. ATS-V intake pages for comparison:
Air Intake for 2023 Cadillac CT4 | GMPartsDirect.com
Air Intake for 2018 Cadillac ATS | GMPartsDirect.com
The issues I'm trying to come through are:
1) Should we keep the ATS-V 15865791 and 23262344 mass air flow sensors or swap out for the 12714453? I can't locate the right sensor.
2) I can't determine if the CT4-V has a MAP sensor equivalent to the 12653415 on the ATS-V.
I'm not 100% on the parts quantities, but it's a minimum of $632 for the above parts--probably closer to $725 once we get the quantities right and the missing pieces accounted for.
84867721 (x1) + 23184138 (qty unknown) + 13384034 (qty unknown) + 84335354 (x2) + 12714453 (qty unknown--may be able to use ATS-V MAFs) + 84938253 (x1) + 84829907 (x1) + 11609530 (qty unknown) + 84435230 (x1) + 11588712 (qty unknown) + 84107707 (x1) + 23414205 (x1) + 11589290 (qty unknown) + 12668054 (not required--identical to ATS-V) + 12638542 (x1) + 12670013 (x1) = $632
2. Side covers on this page (these would be an ideal candidate for CF wrapping, btw):
Covers & Shields for 2022 Cadillac CT4 | GMPartsDirect.com
84861317 (x1) + 84861318 (x1) + 11589289 (x4) + two ID# 4, 5, & 6 push-pins and metal clips = $81
Probably $100 when you get the other hardware.
3. Splash shields:
Splash Shields for 2022 Cadillac CT4 | GMPartsDirect.com
This is where I'm gonna have to dig some more. I believe that only ID #1-4 are required. I want to check out the lower deflector (which supports strakes) because I'm already doing the Blackwing brake ducts on the ATS-V.
4. Forward diagonal braces (unknown P/N):
Confirmed to overlap on top of the rear diagonal braces (rear braces are the same P/N on ATS-V and CT4-V). However I can't find the part number for these yet. I've checked every category on GMP and cannot locate these yet. I also want to see how they bolt to the front radiator support--not sure if we have the bolt holes. If someone can help locate these (red boxes in the picture above) that would be awesome.
#2 ·
Update: rear diagonal braces are not identical, even though you can use ATS-V on CT4-V. Instead of bolting directly to the shock tower, they have a twin bolt pattern that bolts to the front diagonal braces. It's progress... gotta order a set of 22884503 and 22884506 ($50 each).
#7 ·
MAF sensors are completely different hardware, fitment and technology between ATS-V and CT4-V Blackwing. Neither is compatible with the other's electronics or calibration.
Yes, the MAP and TMAP sensors are identical.
By the way, are you the one who emailed these same questions to me a week or so ago?
