Can anyone help me find the lifting points for my 2022 CT4 Blackwing? The searches I have done aren’t showing much.
Thanks, Gary
Thanks, Gary
Thank you!It's probably the same as an ats v since they share the same alpha chassis. Just behind the front wheel and in front of the rear wheel. You can look underneath and see the opening. Its best to use a lifting point jack pad.
What is the purpose in rotating the tires from one side to the other?Hi all. I took a first attempt on rotating the tires. Wasn't a fun experience. I started at the rear driver side and quickly realized that I won't be able to do a jack and Jack stand together. Didn't see very much potential on the front either.... only thing I was thinking was to raise the car high enough to where both tires are up in the air on the same side and I could put a jack stand under the front... doesn't seem like a good idea. Thoughts?
Thanks.I use the pinch welds which are the recommended lift points. I also use these jacking pucks. They have magnets in the center so you just put the center on the pinch weld and it will stay up while you orient your floor jack under it.
