1999 ESC
99' Eldo
have a '99 Eldorado, CC sets OK - will operate 15-20 minutes on the highway - then disengages - can reset -the same thing - runs about 15-20 minutes - cuts off - just inconvenient to have to keep setting CC. Installed used CC module several months back. Any ideas?:unsure:
Where you having this problem before you installed the used CC module?
2013 CTS Luxury, 1998 Eldorado ETC Crimson Pearl
I had the same problem with my 98 Eldo for some time and then it completely stopped working.
After checking the brake light switch which was fine, I ended up replacing the control module under the hood which fixed it. It maybe the module you installed could be bad.
