2004 Platinum CTS-V
I need to replace my rear differential bushing. Discontinued part, GM Part # 19121910.
From reading your topics of the past, I was pointed towards Creative Steel's solution.
04-07 CTS-V Rear Differential Bushing - Creative Steel
What can anyone tell me about the real-world differences between the Red vs. Black? Beyond the standard, "Black is for a Daily Driver and is similar to OEM, Red is stiffer and might be louder". Not looking for install comments, more what to expect from the two different products.
Pro's and Con's of each?
What other options would I have?
· Administrator
'05 CTS-V
The red, being firmer, will transmit some more rear diff noise into the car. It would be awfully hard to quantify how big a difference it really makes. And the rear diff is mounted to the rear cradle, which has 4 big rubber mounts to mount it to the chassis, so it's not like the diff noise would be directly transmitted into the car.
With that said, if you're at all concerned about NVH, then I would go with the black, just to play it safe.
2004 Platinum CTS-V
What is the benefit of the stiffer Red? What are the Pro's?
My car is a garage queen... see's less than 1,000 miles a year... never tracked or driven hard. I'm a slow old man who likes quick cars. LOL
2011 CTS4 Coupe, 2014 ELR, 2018 XT5 AWD
The firmer Red bushing will reduce the movement of the rear diff relative to the rear cradle. This would result in a slightly more planted feel during spirited driving. The trade off would be increased noise transmitted from the diff to the rear cradle. That could increase the cabin noise level.
Based on your description of your driving style you would not gain anything from the Red except the bragging rights of having it. IMHO
2004 Platinum CTS-V
Perfect. I appreciate the advice.
2004 Platinum CTS-V
Discussion Starter · #6 ·
So, to further confuse me...I am in no way "smart" with this stuff... Cadillac did some much overdue recall work on the car. They said that I need to replace both the Rear Differential Front Bushings, Qty: 2, Part # 25742459... I'm assuming this is NOT the same one as the Creative Steel bushing, as their site states that there is only 1 per car.
Advice... Should I order 2 of the 25742459 bushings online, and then get the Creative Steel bushing as well... knock out all three at once?
