95 Fleetwood Brougham / 01 DTS / 11 CTS Lux / 11 DTS Platinum
I'm pretty sure this has been discussed but I couldn't find a thread.
While moving slow, like under 5 MPH and turning the wheel, I hear a creaking or rubber rubbing noise.
Any idea?
04 Deville, 11 DTS Premium, 00 Deville (sold), 02 Deville (sold)
The noise is probably coming from the steering column intermediate shaft rubbing on the shaft seal this is addressed in TSB 02-02-35-003. Look where the steering column passes thru the floorboard under the dashboard. You will see a clear weather tight boot. More than likely this boot is deformed and will need to be repositioned to prevent it from rubbing when the steering column turns.
I knew there was something, thank you.
