2003 Escalade
Hello to all:
Well the blinkers stopped working on my 96 deville. The relay just seems to not work, no flash inside or out on either side. But the weird thing is that the windows, fuel release, and trunk release button also are not working. All of the fuses are good but there is probally a relay or something for the windows huh. I know where the blinker relay is but not the relay for the windows and acc. If anyone could help I would appreciate it. I should have bought an old Caddy flower car or something, minimal electronics and kinda funny lookin.
Thanks:bonkers:
Replace the blinker module to check turn flashers( not the 4 way module) under the drivers side dash. Fuel door and trunk release do they work with the remote, is the car in park, is the valet switch off ?. The power windows have a 30 amp circuit breaker on LH maxi-fuse strip then thru the accessory cut off time delay relay to the large pink wire on drivers side door.Trunk, windows and fuel door are also controled from retained power relay as well several other things does the radio time out after the ignition is turned off(10-15 mins.) if the door is not opened ??.Check radio/phone fuse 10 amp and convenc fuse 20 amp in the trunk fuse block for trunk and fuel release. sts96
2003 Escalade
Well the blinker relay was bad and that was replaced and works great now. the windows still don't work. The valet button is off, the trunk and fuel door don't work with the remote. What fuse is it that works the windows and what not under the hood.
