This is my first forum to ever get on so I'm sorry if I break any forum rules. I have 2 Cadillacs that both have crazy undefinable (so far) problems. The first is a 91 Sedan Deville with the 4.9 liter. The second is an 84 Eldorado with the H4100. I will place the problem with the Eldorado on the next slip.
My Deville is hesitating and sometimes backfiring. Somedays it does better than others and somedays it will or won't have the check engine light on. So far I have:
changed the fuel pump
changed the wires
checked the plugs (they look good but they r to hard to change just for a guess)
changed the fuel filter twice
only used premium gas even though it's $3.50gl here
cleaned the fuel injectors
filed down the leads on the rotor button and the distributor cap
:hmm:done a lot of head scratching
and changed the front motor mount that was completely broken and probably jarred something lose
None of this has changed anything except my motor isn't doing jumping jacks anymore (by the way, stay away from buying foreign parts that bolt holes have to line up on). I also had 2 diagnostic tests run on it. The first one said nothing but the second one said the torque convertor and the clutch were going out. It doesn't act at all like a transmission problem though that may be in the near future.
This is my daily driver and I don't have shop money to send it to them and tell them to fix it. Especially since I just lost my job. So any advice or thoughts would be very helpfull. Thx
changed the wires
