Hello. I have problem with my eldorado biarritz 1988. It starts very vell and alter gets hot engine suddenly stops. I was told that crankshaft position sensor must be replaced. What is The location of it ? I mean in the engine ? Thanks
Discussion Starter #2
I was told to put New crankshaft position sensor in my 1988 eldorado biarritz. Where is it located in engine ? I have to see it so i can order The proper one. Does anyone knows the OEM part number ? Thanks
I believe that your 4.5 V8 engine uses a distributor and internal ignition module so it should not have a CKP - CranKshaft Position sensor.
I don't think an '88 had a CKP sensor.
