About 1 month ago, my courtesy lights, cig lighters, glove box light, map lights, trunk and hood lights and visor lights all stopped working at the same time. The fuses are still good for these items, so I'm stumped. I did notice in the owner's manual that there is a mechanism which turns these items off to prevent battery drain after 15 minutes, but power should be restored when the door is opened again. These items not only fail to work when entering the car at night, but they can't be manually turned on from the headlight switch either. Has anyone encountered this problem, or can you suggest possible things to check other than taking the car in for an expensive electrical diagnosis? Any help would be greatly appreciated.
Thanks, rudye
2003 STS w/BoseNav, 1993 Deville, 1985 Deville
Maybe someone out there has access to the Factory Service Manual for the 1999 Deville. I would suspect that the battsaver module may be malfunctioning or have a blown fuse. I hope it's something simple.
