Ok just wondering i know there are a few who have the system on there STS
but are there any members who put the system on there SLS ?
Yeah thats what i figured should sound the same and bolt up the sameShouldn't be much difference, in either installion or sound
This is what I thought as well. If you are look for a louder sound, you could just take the mufflers off, take them to your local shooting range, practice with your .22, and put them back ondropping almost $1200 on an exhaust for the sound... ouch!
yeah i have been looking i search ebay every week to see if anyone put on one there that is the right systemdropping almost $1200 on an exhaust for the sound... ouch! You might get lucky and find a used one.
yeah but not sure it would bass E-Check after that LOLThis is what I thought as well. If you are look for a louder sound, you could just take the mufflers off, take them to your local shooting range, practice with your .22, and put them back on. .22 ammo is a lot cheaper than $1200.
Never heard of that, but you won't feel 30-40 pounds difference on a low performance fwd 4000lb car. I really wouldn't take that into consideration as you make your decision.also i hear the system is alot light takes about 30 or 40 pounds of the car from what i heard so a corsa in the long run might help with MPG also
but not sure if the performance of the system take away from he MPG to make up for the gain from weight but then run difrant to use up more fuel
ok cool thanks for the infoNever heard of that, but you won't feel 30-40 pounds difference on a low performance fwd 4000lb car. I really wouldn't take that into consideration as you make your decision.
You can get an "estimate" guilt-free; they're not contractsthere is one Muffler shop that does some decent work around here custom work
maybe ill go and check it out
but dont want to go before i have the money
kind of pisses those guys off if you go and bug them about stuff try to get good prices they give you good prices but then you say i have to wait to do this till next month when i have money
Agreed, and not only that - but most of that weight is in those stock fat rear mufflers. That's the part you're replacing at a muffler shop anyway, so you're still dropping weight.Never heard of that, but you won't feel 30-40 pounds difference on a low performance fwd 4000lb car. I really wouldn't take that into consideration as you make your decision.
Pup, here's an SLS that just swapped out the rear mufflers, even had stock tips welded back on. I personally am going to go with something similar to this:
