03 Deville
hey I notice that my 03 deville two cornering light don't come on when the lights come on the two on the side of the car I change the bulbs but nothing is there a fuse for these lights I can check thanks
'98 STS (RIP @ 206,xxx miles)
The appropriate cornering lamp should be ON when the park lamps or headlamps are ON----AND----you are signalling a turn. Are you checking the lamps when the turn signal switch is being used??
03 Deville
ok now are those the two clear lights on the side of the car by the wheels wales not the headlight with the yellow in them
2006 Escalade, 2002 Deville DTS
Those cornering lamps only work when the blinker is activated for the appropriate side. Turn on your blinker and check them again.
