1 - 20 of 21 Posts
Eldorado Etc
Ok well I need some help I don't know what my problem is. I was drivng my eldorado and I watched he temp guage go above the normal halfway mark. I know this has to be a problem with the coolig system. I immediately shut the car off and opened my hood and had some steam I don't know if a hose broke or something. Therefore I was going to put more antifreeze in better yet drain it n put all new in but I don't know where to find the drainplug and where to add it someone help please
Ty Matt
2010 DTS
The drain is on the bottom left (drivers) side, but before you do that you have to find out where it was leaking from and repair that. If it was from the overflow, then get a block test kit from Napa and check the coolant for exhaust gases.
Eldorado Etc
Ok I found it was the fans behind the radiator they are supposed to turn on at a certain degree but they aren't going on where is the fuse located for this fan and if it is not the fuse then what should I do reguarding this problem
1997 Eldorado
they arent turning on when u have your ac on? if u dont have ac on they should turn on slow at 224 about the 1'o clock line on the temp gauge. and fast at 234
Eldorado Etc
Yea they don't go on at all what would the fuse name for the fans be inside the fuse box because I cannot find it
Engine compartment fuse box, Fan1 and Fan2. Probably maxi-fuses (30 amp) in the inner box. Do the blades spin easily ?
Eldorado Etc
When I open that fuse box it doesn't say anything about fan 1and2 I wish. Did lol and if I'm looking at the winsheild only the right one spins freely
1997 Eldorado
you have too pull the black cover off right ? there are some big maxi fues and relays to test the relay just put it on a 9v battery if it clicks its good. or if u have a multi meter
Eldorado Etc
Discussion Starter #10
Yea the black cover but none of the fuses on the fuse indicator read fan one or fan two or anything to do with a fan
Eldorado Etc
Discussion Starter #13
YEa i took the cover off and I didn't see any fan fuse anywhere someone said someing about being a 30 fuse for each fan the only 30 I can find are for the wipers
Eldorado Etc
Discussion Starter #15
Ok when I get home I'm going to try it out n see if I can find the lower fuses because all I saw were the upper ones for the wipers n stuff
Eldorado Etc
Discussion Starter #16
Ok I didn't know that cover cameoff lol I found it the I need a new fuse I hope that's all that is all that the problem is. Out of curiosity why would the fuse break just normal wear n tear or somethig bigger? Thank you so much Talamant3z
1997 Eldorado
no problem. but the fuses are designed to protect the electrical circuits in your car from a short circuit or overload. so somewhere something might have caused it to pop. everytime i go to a junk yard i grab as money as i can find the small ones and the big 50a ones keep them in the trunk you never know when you will need them
Yep - he said only one fan spins freely. If the other is seized or hard to turn, there's the problem.
Eldorado Etc
Discussion Starter #20
so when i get a new fans are they easy to install?? just plug n play with some screws im assuming
1 - 20 of 21 Posts
