The water pump bearing seal can leak, which might be hard to see because you will only see evidence of it underneath the pump. You might have to look underneath the car to see it. The water pump cover can also leak - the gasket is not very well designed in my opinion, and that could also be hard to find. Get the car up to full temperature and search carefully with the engine running. Rev it up a little bit to get the system really moving.rwess said:i checked the waterpump just now, looked at the surge tank and radiater again and seen nothing
