1 - 16 of 16 Posts
I have a coolant leak that's coming from right side under hood. No fog on windows, no antifreeze smell coming from vents and no inside leak on floor. Puzzling. I know the heater core is on right side and not sure if it's going bad. Please give me your thoughts. I called dealership and to install new heater core it's going to cost me $1,000 plus. Haven't had checked out yet to determine if it's the heater core. Wanted to post first to see if anyone else has heard of this problem. 2007 Escalade
2012 Escalade, 2014 SRX
Could be heater core for owners who have not changed their coolant since new, but we have not seen any bad cores at our shops yet, check your hoses if they are original. :)
2001 DTS,2007 STS V8
Check to see if the heater lines (metal lines) rubbed through somewhere. 2 common places are by the trans dipstick and down by the r/s running board. HTH.
I'm about to check now. Thanks
Big Big Red, I'm looking forward to your updates after checking the heater lines! If you would ever like me to check for open recalls on your specific Escalade, or communicate with your dealership on your behalf, don't hesitate to email me. I'm available at [email protected].
Best,
Katie
Cadillac Customer Service
Looks like its leaking by the trans line like you said but I can't seem to locate the leak.
It's defiantly leaking from some hose close to the trans dipstick. It's actually dripping from the dipstick under the vehicle but I can't see where the leak is. Any idea?
Look for rub marks around the metal lines. Check the quick connects also going to the heater core. If its close to the dipstick, move it and check for the line being rubbed through.
Discussion Starter #8
Carmanchris Hey just want to say thanks Carman Chris that's exactly what it was metal line had a hole in it.
Discussion Starter #10
cadmanchris said:
No problem. Did you fix it yet?
Not yet. Scheduled for Monday to get fixed. Hey can you help me with clunking noise issue? When I'm traveling at low speed ESP in stop and go traffic I feel and hear a clunking noise when I accelerate. I've greased the slip yoke and it didn't fix it.
Sounds like a broken engine mount. Normally the drivers side. They do leak fluid when they are broken, and the drivers side would leave a brown rust colored stain on the front diff.
Discussion Starter #12
This sound is coming from the rear. It's in the driveline. Sometimes it clunks hard changing from 2nd to 3rd. Called the dealership and they said it was normal. I've saw several other GM owners post with the same complaint. It's very annoying.
Also I changed the rear diff fluid with GM Auto Trak fluid. Still clunks :(
Oh ok. I must say that my 07 has that occasional clunk in the driveline. I did update my TCM with the latest software, but I still get it at times. One more thing to check are the u-joints. Hope I could be of some help.
Discussion Starter #14
Yeah checked those too, they're good. I saw where a guy put a racquetball in the slip yoke and it'd iced the clunk. Also heard of a nickel plated slip yoke fixing the clunk. I want it gone.
Was just helping another member and noticed the bulletin 09-07-30-00I. It mentions the pump fluid seals and also the possibility of a cracked 1-2-3-4 or 3-5-R clutch housing. Are you still covered under powertrain?
Discussion Starter #16
No not under power train. I purchased from a Nissan dealer. Only has 78k on it.
1 - 16 of 16 Posts
