So knowing the thermostat is located in the back of the engine and the engine has 180,000 miles. I figured thermostat housing leaking, it could be original, makes sense, lets change it.
Removed the t-stat housing and wouldn’t you know it. There’s another housing below the t-stat housing for the heater core hoses. And that housing looks like a pain to get to
So which component is causing my leak. T-stat housing, heater core hose housing, clamps, hoses, the alternator, brake pads, which one?
With everything installed it’s so freaking tight and compact back there you can’t see anything clearly. The o-rings for the t-stat housing and cross over pipe looked relatively good. And I did not pressure test the system before taking apart
So know I have to decide. Take a chance with replacing the t-stat housing and keep my fingers cross. Or go for the heater core housing also.
I’m sitting on the toilet taking a shit, while figuring out what’s my next step 😁
Damn these engineers
