I have a 92 deville and i had the coolant system flushed and now i smell coolant outside of the car, after reading some posts i read that maybee i should not have had it flushed?? The shop told me it was coolant that spilled. Could anything real bad have happend with the flushing?
1989 Sedan DeVille is now just a fond memory ....
Keep an eye out for leaks. Do you know that the shop you used put the GM pellets in the coolant? That is VERY important in our engines.
The main argument against "flushing" is that it leaves tap water in the system which will eventually cause corrosion.
1999 STS - diamond white
Yea. Unless you flush with a premix, you'll never know if you have the right coolant/water ratio again.
Probably just spillage. Look for leaks though. They may not have tightened everything back up.
2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
To rule out the spillage issue, hose down the entire engine compartment very well. Do not use a high pressure stream of water. Volume is your friend here. Coolant that is left to evaporate on it's own, can take a long time before the odor goes away. By rinsing, you will remove almost all of the residual coolant, and the odor will go away much faster.
Don
