1 - 10 of 10 Posts
I have a 2013 V Coupe and can't connect the IPHONE 5s to the system with the factory supplied conector . Does Apple or someone else sell one that works ? Thanks Jeff
you have the adapter that connects into your ipod/iphone and then you have they USB and Aux plugs both connected? You try swapping over to the USB/Aux section in the entertainment system?
Also try opening up the music app and playing a song. I know I've had issues where it's connected by won't "recognize" it unless you manually play a song via the iphone.
2009 CTS-V (TR-6060, Black Raven/Ebony, Recaros, Ultraview)
I have a 2009 and my 5S works fine.
I have the GM supplied large connector that only fits Ipods and old IPHONES. The 5s has a mini connector , which doesn't interface . Thats why I asked about other connectors. Thanks. Jeff
The smaller connector is called a "Lightning" connector. No clue if GM offers a Lightning cable, but you can get 30 pin to Lightning connector adapters.
Thanks. I should have " known " that would be the solution but glad to know it works and is available. Jeff
2011 WD Vagon 6MT "Unobtainicorn"
Yeah it's kind of kludgy to have both the GM adapter and then the Apple Lightning adapter, but I can verify it does work.
Discussion Starter #9
Bought one last night , it works . I wish it would do more than play music ( use maps , video , etc ) , oh well. Thanks again.
1 - 10 of 10 Posts
