1 - 9 of 9 Posts
2005 CTS-V
I noticed the other day when checking my clutch fluid that not only is it a little low (I just got a certified 05 with 23K miles), but the fluid is gelling around the sides of the reservoir. I've never seen this before, but I won't worry if it's normal. Anyone have any thoughts?
'05 CTS-V, Powered by Chevrolet
Mine was like that when I first bought it...just had the system flushed...never came back
Mine too. I didn't get to flushing it but I did remove the fluid and cleaned out the reservoir and replaced it with fluid from a newly opened bottle a few times. I haven't see the 'gel' again since. It is wierd as I haven't seen this before in other vehicles.
04 CTS-V with a little hp persuasion device
They use petroleum jelly from the factory to assemble parts that contain orings. Its probably the petroleum jelly that has eventually worked its way out of the slave or master.
2005 CTS-V
Thanks for the advice, everyone! It's going into the shop this week for some warranty stuff, so I'll see if I can get them to flush the system.
2005 CTS-V
Turns out the clutch fluid was leaking out onto the bell housing. I'm glad I checked the fluid level! The dealer has ordered a new slave cylinder and will install it and flush the system. I love warranties!
Mine is doing the same thing as we speak. I need to replace mine soon.
P
Guest
Usually it's soap!
1 - 9 of 9 Posts
