21 - 40 of 43 Posts
2011 CTS Coupe FE3, 2003 Thunderbird, Gone 2013 ATS, 02 Deville
for all you that can not get the wheels to spin and power slide thru a turn, take the car one of the many race tracks that have a track day. If you car is safe with good tire and can pass their inspection then they will teach you how to drive it fast and in control.
08 CTS DI
You still need to have the right gearing in the rear end to help make that possible. I'm curious to know how competitive mode compares to a tune performance wise since the ability to squeal the tires when it's active is clearly an indication of more power available than is usually accessible. I wasn't aware of it until recently.
2014 CTS4 Sport Wagon*2016 CTS V-Sport Premium
Competitive Mode should give a slight increase to steering effort through the steering wheel as well...
I drive my CTS Sport Wagon in Sport Mode most all the time (seems to shift faster) and Competitive Mode when the weather is nice out...I notice the difference with my 3.0...
Good luck with yours,
Bill
08 CTS none DI 3.6
Ok you guys have saved my shiny backside. Texas 08 CTS just went to Colorado Springs and hit snow. 6 inches plus and traction control just kept flashing and the car just kept sliding backwards. Some fancy button pushing and no more traction control and I was able to move the car even if it was sideways up the hill...
'12 CTS Performance Sports Wagon AWD
Don't you hate it when you have 6 inches and all you can do is keep flashing?
Sorry... Couldn't help it...
Not sorry..
Reactions: HurstGN
2013 Cadillac CTS 3.6 Sport Luxury
I think the “added power” is just a change of calibration of the throttle.
For some reason the throttle reacts really slow in normal mode. But in sport and comp. mode you can take off like a bullet.
Just like if you dump the clutch on a manual you get wheel spin.
· Super Moderator
I believe this only works with a vsport wich is not AWD
Competitive driving mode is available on all CTS models.
Defer to the owners manual for proper operation.
'14 CTS-V LongRoof; Audi RS6 Avant; '16 ATS-V Sedan gone; '10 CTS LongRoof gone
What? RTFM? Just tell me, it's so much easier.
  • Haha
Reactions: Long
Competitive mode does nothing to the runability of the engine. It adjusts the steering, the transmission shifts and how sensative the traction control is. Does nothing with the TB or Gas pedal. You need a pedal controller to change how the pedal and TB respond.
· Super Moderator
2023 CT5-V RWD / 2020 XT6 Sport / 2024 Lyriq AWD (reserved)
Reading the manual for the win!
And never mind the fact that this thread has been resuscitated to respond to somebody who hasn't been active here in over three years and who, in turn, resurrected a thread that had been dormant at that point for over a decade.
when the weather is good round here, I am almost always in Competitive Mode as well as Sport Mode with my CTS Sport Wagon 3.0 V6...response is noticeably better but it still is no huge improvement but I feel it is less laggy with the throttle response and drivability
Bill
· Super Moderator
Bill
Agreed. I will add that it doesn't do much to transform AWD versions of the CTS. I suspect that the difference is more noticeable with RWD versions.
I would like to experience the differences in RWD over my AWD sometime...had I known there were that many differences in actual road feel/performance I might not have bought my CTS4 Sport Wagon...but then I wouldn't have met all of you all those years ago...
Bill
From the owner's manual;
Competitive DrivingCompetitive driving may affect the vehicle warranty. See the warranty book before using the vehicle for competitive driving.
Notice: If you use your vehicle for competitive driving, the engine may use more oil than it would with normal use. Low oil levels can damage the engine. Be sure to check the oil level often during competitive driving and keep the level at or near the upper mark that shows the proper operating range on the engine oil dipstick.
Ride Control SystemsTraction control system (TCS)
The vehicle has a Traction control system (TCS) that limits wheelspin. This is especially useful in slippery road conditions. On a rear-wheel-drive vehicle, the system operates if it senses that one or both of the rear wheels are spinning or beginning to lose traction.
On an All-Wheel-Drive (AWD) vehicle, the system will operate if it senses that any of the wheels are spinning or beginning to lose traction. When this happens, the system brakes the spinning wheel(s) and/or reduces engine power to limit wheel spin. The system may be heard or felt while it is working, but this is normal. The TCS/StabiliTrak warning light flashes when the traction control system is limiting wheel spin. The TCS/StabiliTrak warning light comes on if there is a problem with the traction control system. When the TCS/StabiliTrak warning light is on, the system will not limit wheel spin.
Adjust your driving accordingly.
SeeTraction control system (TCS)/StabiliTrak®Light page 5-24 for more information.
TCS automatically comes on whenever the vehicle is started. To limit wheel spin, especially in slippery road conditions, the system should always be left on, but it may be necessary to turn the system off if the vehicle is stuck in sand, mud, or snow, and rocking the vehicle is required. See If the Vehicle is Stuck on pages 9-11 for more information.
See Winter Driving on pages 9-9 for information on using TCS while driving in snowy or icy conditions. This button is located on the instrument panel (CTS) or the steering wheel (CTS-V). Press and release the TCS/StabiliTrak button and the traction-control system will turn off and the TCS/StabiliTrak warning light will come on. Press the button again to turn the system back on. For information on turning StabiliTrakoff and on, see StabiliTrak Systemfollowing. Adding non‐dealer accessories can affect your vehicle's performance. See Accessories and Modifications on pages 10-3 for more information.
StabiliTrak®System
The vehicle has an electronic stability control system called StabiliTrak. It is an advanced computer-controlled system that assists with directional control of the vehicle in difficult driving conditions.StabiliTrak activates when the system senses a discrepancy between the intended path and the direction the vehicle is actually traveling. StabiliTrak selectively applies braking pressure at any one of the vehicle's brakes to help steer the vehicle in the direction which you are steering. When the system activates, this warning light flashes on the instrument panel. A noise may be heard or vibration may be felt in the brake pedal.
This is normal. Continue to steer the vehicle in the intended direction. If there is a problem detected with StabiliTrak, SERVICESTABILITRAK displays on the Driver Information Center (DIC) and the TCS/StabiliTrak warning light comes on the instrument panel cluster. When this message and warning light are displayed, the system is not operational. Driving should be adjusted accordingly. SeeDriverInformation Center (DIC) on pages 5-27 and Messages and Traction Control System (TCS)/StabiliTrak®Light on pages 5‑24formore information.
This button is located on the instrument panel (CTS) or the steering wheel (CTS-V).StabiliTrak comes on automatically whenever the vehicle is started. The system should be left on to help assist with directional control of the vehicle. If StabiliTrak needs to be turned off, press and hold the TCS/StabiliTrak button until the TCS/StabiliTrak warning light comes on and StabiliTrak OFF comes on the DIC. More steering effort is required when the system is turned off.
If cruise control is being used when the StabiliTrak activates, the cruise control will automatically disengage. When road conditions allow, reengage the cruise control. SeeCruise Control on pages 9‑41formore information. Competitive Driving ModeTo selects this optional handling mode, press the/StabiliTrak button quickly two times, and STABILITRAKCOMPETITIVE MODE displays in the Driver Information Center (DIC).
While in the StabiliTrak CompetitiveMode, the TCS/StabiliTrak warning light comes on, TCS does not limit wheel spin, and more effort is required to turn the steering wheel. Adjust your driving accordingly. Press the TCS/StabiliTrak button again, or turn the ignition to ACC/ACCESSORY and restart the vehicle, to turn TCS back on and turn the TCS/StabiliTrak warning light off. Notice: When traction control is turned off, or Competitive DrivingMode is active, it is possible to lose traction. If you attempt to shift with the drive wheels spinning with a loss of traction, it is possible to cause damage to the transmission. Do not attempt to shift when the drive wheels don't have traction. Damage caused by misuse of the vehicle is not covered. See the warranty book for additional information.
Magnetic Ride Control;
With this feature on the CTS-V, the Magnetic Ride Control system adjusts the ride of the vehicle to Tour or Sport modes. Magnetic RideControl monitors the suspension system to determine the proper system response.TOUR: Use for normal city and highway driving. This setting provides a smooth, soft ride
.SPORT: Use where road conditions or personal preference demand more control. This setting provides more “feel,” or response to road conditions.
The setting can be changed at any time. Based on road conditions, steering wheel angle, and vehicle speed, the system automatically adjusts to provide the best handling while providing a smooth ride. The Tour and Sport modes will feel similar on a smooth road. Select a new setting whenever driving conditions change. The Driver Information Center (DIC)briefly displays SUSPENSION MODE TOUR or SUSPENSION MODE SPORT on vehicle startup or when a new mode is selected. Press and release this button, located in the center of the instrument panel, to change modes. Limited-Slip Rear Axle Vehicles with a limited-slip rear axle can give more traction on snow, mud, ice, sand, or gravel. When traction is low, this feature allows the drive wheel with the most traction to move the vehicle. The limited-slip rear axle also gives the driver enhanced control when cornering hard or completing maneuvers, such as lane change.
This happened a couple of years ago; as I remember. On my 2011 CTS RWD Coupe, I had all the nannies on (normal driving position) and was driving hard thru a turn. I gave it more throttle, and the car's front tires started to slide as did the rear tires with the limited-slip rear axle. The car did not like all that happening and started flashing all the nanny lights, the throttle disengaged and the traction light was flashing. The car corrected itself from the 4-wheel drift. The engine went to limp mode and the dash brake lights started blinking. The car stayed in limp mode.
I stopped the car, shut the ignition off, and restarted the engine. The car adjusted all its nanny positions back to normal again and drove as if nothing had happened.
The moral to this is; If you want to play turn-off all the nannies and PLAY.
Happy Motoring!
2011 CTS coupe 1989 Allante
Was a Top Gear (original UK) where a Crossfire beat a Viper in a 1/4 mile drag. Have always preferred small, overpowered cars for solo II autocross. Have my second coupe now (first was black).. 3000 lbs and 160" long is grape for slaloms and OHC-6 for long straights. Is the coupe Mercedes never made.
Did you pick up a Crossfire SRT-6???...that's what beat the Viper in the 1/4 mile drag...nice acquisition...
Bill
21 - 40 of 43 Posts
