1 - 2 of 2 Posts
97 Catera
Ok as the title states i plugged in my code reader after the check engine light came on and im getting a p0507 code (Idle Control System RPM high)
My car usually runs around 900-1000rpm when in park but as soon as it's in drive it comes down to around 400-500rpm.
Im assuming that it running at 900-1000rpm in park is not right?
So is my problem some sort of sensor? And if it is, can anyone please tell me what its is and where it's located?
97 Catera
Discussion Starter #2
Just for everybodys information i did seach my problem on the entire forum before i posted and have done all the basic checks as to what my problem could be.
I have check for any vacume leaks and came up with none, cleaned my throttle body and maf sensor, put in a new air filter, also sea-faom'd the car, and did an oil change.
So can someone/anyone please give me some advise if you may have any as to what i can do or look for. Thanks
1 - 2 of 2 Posts
