1 - 2 of 2 Posts
2001 Cadillac Eldorado ESC
need more indepth info on these codes: P0171, P0174,( i know these are lean bank codes, but what do they mean)
2010 DTS
They mean you have a vacuum leak. On the 2000+ engines the most likely place is a rip in the plenum. That is the rubber coupler between the TB and the manifold. The rip is usually on the underside so it will not be visible. Spray some Brakleen around it and listen for an RPM increase.
1 - 2 of 2 Posts
