1 - 15 of 15 Posts
deville
my car wont start are turn over but all the lights are bright can someone please give me the codes to check and see what's wrong with my car..how can i clear the computer out? also i saw some say starting disabled due to theft system problem the only thing i did was unhook the battery and hook it back up..i waited the hour etc..i unlock it from the outside....i waited the 3 min count down then it say start it didn't start....so please help me out i have looked everywhere for answers...this is very stressful:bigroll::bigroll:
See the sticky at the top on how to pull the codes.
Are you saying it won't start or even crank?
deville
ok can you walk me thru to see where the codes are...and no it wont turn over only the lights will come on..
Simultaneously press and hold the OFF & WARMER buttons. Once in the diagnostic mode HIGH FAN = YES and LOW FAN = NO to the prompts. Answer no till you see "CLEAR CODES?".
deville
thanks ill go do this now and will get back to you in 5 mins....thanks alot bud
deville
ok this is what i see I052 history no pcm code.....no cranking sound just lights turn on i hear the fuel pump sound...it was working find when i turn it off my battery was acting up i change that out and disconnected it waited the hour...i just push clear still nothing.
deville
Discussion Starter #8
Battery is new? No crank when the key is turned at all? Just dead silence?
you are correct dead silence no turn over just the lights comes on then they go off like always..i'm very clueless because my car was running fine..i unhook my sound system power wire because it ran my battery dead but while unhooking i hit some and spark fire from pliers touch metal but the car was off tho.
Oh, now you tell me. Check all the fuses. You may have blown one. Especially any relating to the starter.
deville
Discussion Starter #10
under pcm ? i see
7.2 PD01,103 PD02,102 PD03,102 PD03,16 PD04,16 PD05,13 PD08,.0 PD10,0 PD11,0 PD12,21 PD19,0. PD30,0. PD31,.45 PD32,.45 PD33,0 PD34,0 PD35,128 PD36,128 PD37,128 PD38,128 PD29,17 PD70,11 PD71,00 PD72,30 PD98,514 PD99
--------------------------------------------------------------------------------------------------------------- NOW i went and press eng/met and reset together i see this set timing mode......service ride control.....switch problem....starting disabled Theft system problem
deville
Discussion Starter #11
all fuses are good check every one of them in the trunk and under the hood none are blown
under pcm ? i see
Those are not codes. They are parameters or overrides. Answer yes to PCM? and then no until you see PCM CODES?
1 - 15 of 15 Posts
