2002 Deville DTS
Air Mix Door #3 Inoperative Error. I keep getting this code. Where should I look to fix the problem? Thanks for any help.
B0428 - Air Mix Door #3 Inoperative Error
the #3 mix door is for the back seat temp -
it is actually controlled by the "inner" part of the #2 mix door actuator -
the above pic is the back side of the #2 mix door actuator -
the larger outer square shaft controls the #2 mix door -
the smaller inner round-looking part is supposed to be "D" shaped -
and that controls the #3 mix door -
this one is worn out - and typically throw the B0249 or B0248 codes
the part you need is ACDelco 15-73428 - $56.82 - with free shipping -
http://www.amazon.com/ACDelco-15-73...automotive&vehicleId=1&vehicleType=automotive
you will be happy to know that it is VERY easy to replace -
by removing the glove box -
go here for instructions - with pics -
http://66.226.74.47/~electricconnect/2001-cadillac-deville-dts-passenger-side-air-stuck-on-cold/
2002 Deville DTS
basscatt, Thank you for the quick reply and all the wonderful information you have provided. I am sure this will help make the job a lot simpler. I do have a cd changer in my glove box. Would you happen to have information on how to take that out? Al;so thank you for the link on where I can get this part for a reasonable price.
Thanks again, WVUDave
