Eldorado Touring Coupe
Hello everyone,
Lately my '94 Eldorado Touring coupe has been having a problem with the speedometer. Every now and then (usually when the engine/trans is hot ~50 minutes of driving) the speedometer stops working and only reads 0 MPH. At that time the servace engine soon light becomes lit with it displaying code PO24 (Vechiel speed sensor signal to TCC).
From what I read online (my manual sucks!), it appears to be a ~$70 speed sensor behind the drivers side wheel on the transmission bell houseing (around 11 o'clock maybe?).
I looked for a while with the eldo up on jackstands and wheel off; however I couldn't find the actual sensor. Can someone please point me to where the vechle speed sensor (the easy one, outside the tranny) is located at? Or better yet a picture?
Also, how hard is it to replace? I read that it was rather easy, but I'm no pro and nor do I have a huge array of tools.
Please help me find the Speed Sensor
Thank you,
-Jake
jakej said:
the VSS is located on the top of the passenge side of the transmission, it is held in with one 10 mm bolt and has a small two wire oval shaped connector on it. I think that you may have loose connection or a broken wire at the sender that is causing an intermitant connection.. check the wiring carefully as the wirers seem to break just inside the connector
hope this helps.....:halo:
Thanks, that helps me a lot. Everyone has been telling me that it was behind the drivers side wheel, so I was looking on the drivers side.
