1 - 8 of 8 Posts
I got check engine light (09' Escalade ESV) the code only one P0174.
But I might be drew up my self, I fueled with 87 instead 91/93, Why? I don't know, may be experimenting.
thanks for help
ok anyone has this problem ? Solve how? MAF cleaning, vacuum leak, fuel pump or fuel filter
Yes it's I cleaned MAF and reset light. I will drive 20-30 miles to see effect today.
thanks for help
Check the PCV hose. It's under the engine cover and runs on the top portion of the engine from the rear.
thanks for help
The PCV hose is the small hose just under the hose seen in the picture
Discussion Starter #8
Ok guys the weather is perfect in VA.
So I went under the hood and find this vacuum tube disconnected from the intake manifold.This tube located on same side as it filter.
1 - 8 of 8 Posts
