2004 CTS-V
Anyone running a combo similar to this? What was your RWHP gain?
none
Depending on the cam and heads selected...you should expect 385-415 RWHP.
I installed stock LS6 heads, LG G5X3 and stock exhaust on my 04 GTO and put down 369. With headers the car touched 400.
The ported heads should be worth a bit more and the selection of cam will be the greatest change.
T
Guest
I have this set up! I'm at 427 RWHP 395TQ. This is with a small cam. SW Long tube headers, and no cats.
alcast082 said:
not bad, those are good numbers, How much should i expect to spend on a package like this???
ball park
Typical heads/cam/installation/tuning costs ~$4.5k and, depending on size of cam, will yeild 440 RWHP - 415 RWT. Realistically, though, expect the "caddy-cam" motors to be in the 410 RWHP / 390 RWT.
Adding headers, UD Pulley and other "bolt-ons" can easily run the cost to ~$7.5 and again, depending on size of cam, will yeild 475 RWHP - 440 RWT. "caddy-cam motors will be more like 440 RWHP / 410 RWT range.
Hope that helps,
Charlie
