none
I am told these fit our cars if we swap the flywheel as well. Is this a good choice for a maggied car? Should I consider a lightened fliywheel now as well? If anyone has done this, did you need to add anything more than just a flywheel?
'05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
You'll also need the LS7 slave, or a space with your stock slave. Everyone recommends using a new slave though.
I recently installed an LS7 clutch with a 16lb flywheel. Stock LS7 flywheel is 28lbs and the V flywheel is 45lbs. I am surprised how driveable the car is after loosing about 30lbs of rotating mass. No stalling issues at all.
Just make sure to mark the driveshaft before taking it off.
05 Cts-v Ls7 Clutch/Fly, Cam, LEDint/ext, side exit exhaust
The LS7 parts are less expensive than the LS6 parts also. Future clutch jobs are cost less, and parts are more readily available.
