Every 3 or 4 days my climate control system shows "climate off" and will not turn on.
I have to turn off engine and restart. Then climate control system is back on.
Anyone else have this problem? If so what was done to correct this problem?
This was a common problem. An over the air update solved it for me. Keep in mind that sometimes it will show this message for a few seconds and then show the climate settings.
First you must have a WYFI Data Plan Subscription
If there is a software update for your car it is sent to your car. Normally you will see a software alert message on the INFO Display.
You can go to Settings/APP and from there check to see if there is a software update. If there is a software update you would than click on it and proceed to down load it.
I have heard both pros and cons about the over the air down load. I do not know if very many software updates are being sent over the air. As you know you can all ways contact the service department to see if there are any new software updates for your car.
It appears the update worked. The climate control system works ok now.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
Cadillac Forums is the perfect place to go to talk about your favorite Caddys including the ATS, CTS, SRX, Escalade, LYRIQ, Vistiq, concept and future Cadillac models.
