1 - 8 of 8 Posts
· Administrator
Which car/engine?
For the 2002 you get into the DTC readout, initialize the sequence and let the codes/modules scroll through to the end, and the DIC will ask "Clear all codes?" Answer YES if that's what you want to do.
If you simply leave any History codes alone they will self-clear after XX start-run-drive cycles during which the fault is not detected. Current codes will remain until you repair the problems- in that case clearing codes accomplishes nothing because as soon as the fault is detected the codes set again and maybe messages and icons appear.
· Super Moderator
2010 DTS
Answer NO to PCM? and it will go one and on asking if you want to go to other codes. Once it says "ALL CODES CLEARED", just push Metric to exit the diagnostic mode and then back to English .
· Administrator
So the 2002 Eldorado does not have the 3-switch DIC control buttons on the right side?
(some Googling for 2002 DIC images says "NO!".)
........ in which case my Seville DTC process will not work.
1 - 8 of 8 Posts
