I have an 07 STS with the 3.6L V6 and have been chasing a misfire on cylinder 3 for the past month or so. If I’ve read correctly, cylinder 3 (and ignition coil C) is the middle one on the passenger side. So I’ve replaced the spark plug and the ignition coil as well as both valve cover gaskets and all 6 spark plug tube seals. Yet the misfire still remains. Any ideas on how I can take care of it? Thanks in advance
Premium Member
Swap fuel injectors with another cylinder and see if the problem moves. Spray a little water on the exhaust manifold with it running to verify your working on the right cylinder. The one misfiring will be cooler.
08 STS 1SG HUD ACC F55 AWD, 08 STS 1SG Platinum HUD ACC F55 RWD
Agree mlAN. That goes for both injector and coil wires or connector. Good Luck.
