I had my car outside during a huge rain a few weeks back. While the trunk stayed dry, I had water an inch and a half deep in the rear footwell behind the driver, plus the headliner and "C" pillar cover were soaked.
I just got the car recently and knew by the junkyard number on the sunroof track that it had been replaced (although it works perfectly and silently...), so I figured that with the amount of water, the drains had to be disconnected...
After looking at the service manual, I saw that the sunroof drains through the trunk, so I wanted to check those first. I saw posts here about compressed air, but that is absolutely NOT necessary.
I pulled out the first drain (all you have to do is pull back the trunk lining on the forward-most part of the trunk sides and look, there is a tube on each side that goes through the floor just in front of hte wheelwell). I looked at the ennd of the tube and it was totally plugged with dirt and grime. I took a small pick and got all of the plug out and all of a sudden, water started coming out. Probably 1/4 cup in total -- basically the entire tube was filled. I found the same thing on the other side.
Once I had the plugs out, I blew through the tubes and could tell they were clear. If you need more than lung pressure, you've got something very wrong with your drain system! With them clear, I added about a pint of water into each side of the sunroof channel and saw the water drain right in front of the rear wheels and behind the front wheels -- exactly as they are supposed to.
I'm confident that I'll have no more leaks now. With the rear drains filled, the sunroof tray filled up and the water had nowhere to go, except inside the cabin... now I'm back to normal.
It's a simple and easy procedure... shouldn't take more than five minutes... so get out there and check!
