1 - 11 of 11 Posts
2k1 STS
My check engine light came on the other day in my '01 STS. She seems to be sputtering a little bit at idle, but nothing too bad. I ran the OBDII codes and came up with 2 current and a handful in history. I searched here and google for the 2 current codes, but can't find anything on them at all.
PCM d0171
PCM d0174
Anybody know what is up with these two? Is my car doomed?
2k1 STS
That's probably it, although I could of sworn it was a D. Now I'm off to figure out what that means. Thanks for your clarification.
98 Deville, '15 Ford Fusion Hybrid Titanium, '12 Ford Escape
No problem...I'd give more info but I don't have my FSM with me.
2k1 STS
Looks like a tear in the plenum could be causing this. This doesn't look like too difficult of a procedure to do myself. Does anyone know how easy or difficult this is?
2k1 STS
Should I try the spark plugs and wires before I try the plenum thing? That seems easier than removing the intake and replacing the plenum.
I thought the plenum was in the spark plug wires? Someone else may need to chime in now. :eek:
'98 STS (RIP @ 206,xxx miles)
PCM d0171
PCM d0174
Given that these are P codes, this is an unmetered air situation - not an ignition or fuel supply problem.
There is a rubber sleeve type piece that has a history of cracking and allowing air to be pulled into the intake; air that is not measured by the MAF sensor. Hence the lean condition.
You have a vacuum leak common to both banks. The plenum is a common leak point in the 2000+ engines. The "plenum" is the rubber coupler between the TB and the manifold as opposed to the intake manifold on most other engines. Check the Tech Tips section. I just copied a "How To" into that section.
1 - 11 of 11 Posts
