· Administrator
Re: check engine light
Let's move this to the proper forum..........
and your car has its own built-in code reader/scanner system. Use the sticky post just above this in the Deville forum - "How to pull codes". Study and use the proper year/car group for OBD-II. --------hang on ........
· Master of the Dark Art of Diagnostics
How can I reset my check engine light on my 2001 dts
the check engine light only illuminates when there is a problem -
so - you don't want to simply shut it off -
you need to find out WHY the light came on -
and you don't need to take your car anywhere to read the codes -
you have a built-in scanner - so you can do it yourself -
to check for Diagnostic Trouble Codes -
if you don't know how -
go here and read the ENTIRE post -
http://www.cadillacforums.com/forum...ncluding-1985/138257-how-pull-codes-dtcs.html
if you have any codes - post them here -
ALONG WITH THEIR DEFINITIONS -
