1 - 1 of 1 Posts
constantly getting the CHECK COOLANT LEVEL message - and the coolant level is correct?
TRY THIS
there are actually TWO parts to the sensor -
built into the tank is a donut shaped magnetic float -
the green thing in this cut-away pic - (thanks Sub409)
584652
SOMETIMES that float - or the center post that the float rides on - gets all crudded up - and sticks -
and SOMETIMES this CAN be cleaned using various soaps - solvents - cleaners - etc -
and shaking the crap out of it -
on other occasions - the sensor itself has failed -
this is the part that the blue harness plugs onto - in the pic -
it was ALWAYS reported that this sensor is NOT replaceable -
actually - the coolant level sensor IS replaceable -
remove the surge tank -
unplug the harness -
and simply pull the sensor straight down -
it is a tight - friction fit -
the replacement part is STANDARD FLS16 - $10.25 - including shipping -
ROCKAUTO.COM
1 - 1 of 1 Posts
