1 - 2 of 2 Posts
1997 Professional Chassis Raised Roof Presidential Limousine
Any special procedures to do this? Do I need a TECH2 to activate the abs or something? Using a vacuum bleeder.
2007 DTS
Buy a moisture meter and keep bleeding until reads OK (less then 3% water). Don't let reservoir get to low and get air get into the ABS. No special tool needed then.
If you example disconnect a caliper and let the reservoir drain through the brake hose because the cap was left off the master cylinder then it gets complicated, Tech2 etc. Been there done that.
1 - 2 of 2 Posts
