2005 Red Line CTS-V
Yes i did a search before I get any hate mail, but just looking for some guidance on changing left side DRL/left turn signal 05 V
2005 Platinum CTS V-Headers+3in pipes
drive the car up some ramps, drop the plastic underbody panel, reach up behind the fogs and twist off the drl bulb and replace.. i have never had to do it but im guessing that this would get the job done.
2005 Red Line CTS-V
kind of what I fugured, just did not know if there was some special VOOOO-DO to it. Thx
2010 Thunder Gray 6MT
I Just did this not long ago...no ramps needed. If your working on the driver side, turn the wheel all the way inward giving you room. Remove the 3 push pins starting from the bottom. Once removed you can peel the plastic back and get your arm inside. Took me about 10 minutes per side the first time. I can do it in 5 or less now.
It's a little tight so hopefully you don't have Hulk Hogan pipes.
