Changed rear differential fluid on 09 AWD CTS...Low from the factory!
37K views 27 replies 16 participants last post by  redheadedrod
So I decided to change out the rear differential fluid in my AWD CTS, largely because I occasionally would get a "thud" from the rear end after I'd stop and go again after long periods of highway driving. Like much of what I read, the differential oil was black, really black. There weren't many metal shavings on the magnetic plug, which is a good sign. However, the biggest concern I had, and as I have read elsewhere it's an ongoing issue, is that the differential was under filled. :confused: I pulled out a quart while the fill took a quart and a half. I used Amsoil Severe Gear® Synthetic Extreme Pressure (EP) Gear Lube 75W-90 (SVG) (2 Quarts) and Slip Lock® Differential Additive (ADA) (1 tube @ 4 oz). Remember you ONLY need the slip lock additive if you have the AWD with limited slip differential.
I am glad I did it. 39 bucks and I feel I saved the back end a lot of wear and tear. My CTS has 37,000 miles.
#3 ·
Hey MoFex, did you check from what you collected to see if it was a low fill from the factory? Just curious if others are experiencing the same thing. i am not sure if a half quart makes much of a difference, but it was a little disconcerting.
#5 ·
I have an 08' AWD with approx 43,000 miles. Your comments have caused me to go ahead and do the fluid change on my rear dif. as well. My question as far as the additional additive goes, how do you know if the car has the limited slip dif or not ? I assume with mine not having the performance package, I will not have it ?
#7 · (Edited)
Look in the trunk, on the underside of the spare wheel well cover and look for the option code G80 on the service parts identification label.
G80 - Limited Slip Differential
ps - I have about 15,000+ miles on the AMSOIL Severe Gear 75W-90 in my CTS4, went in approximated 5,000 miles. Don't know if was low, I paid someone else to do change out both axles.
#8 ·
there's one question I never see answered in these threads;
where you lifting the vehicle from the rear only or were you using an acutal lift and/or had the car up on 4 stands on a level surface?
using the latter method is how you're supposed to do it. Raising only the rear will overfill the diff and will not remove all of the oil which might make it appear to be underfilled.
#12 ·
if the Dexron LS weren't $40-50 for 2 quarts, I'd use the OEM stuff. Just changing it for regular driving is the critical part in this case really, the added bonus being that the 'better' fluid is also < half the price :D
#13 ·
Good question. When it only holds 1.5 quarts is it seems like a lot to me ... but as far as if being low nearly half a quart is a problem in terms of how the differential operates, wear and tear, I don't know. All I know is that if the recommended capacity is 1.5 then I expect it to come from the factory with 1.5 ...
#23 ·
I did mine (front and rear) at about 60k and used Mobil1 synthetic differential fluid with the LSD additive in it already.
My car was shuddering when making a hard turn at a light and has been quiet ever since.
The back was easy to drain and fill. The front fill plug was a little hard to find and is located on the side facing the front of the car. I also did the transfer case fluid which I got from the dealer.
I know a mechanic friend with a lift at home who did them for me. To get at the fill bolt on the transfer case, you have to unbolt and lower the tail of the transmission enough to get at it because it's high up in the transmission tunnel. The drain bolt is removed easily.
#24 ·
There are a couple different write-ups, that explain ways to drain the transfer case without loosening or unbolting anything. I used a 120XP Gearset ratchet wrench and slit the floor pan insulation around the fill plug and was able to drain and fill the transfer case fluid. At 56K miles, the fluid was mostly black and needed changing. I also added some Lubeguard anti-shudder additive for transmissions, and it cured my front end scrubbing (binding) on tight turns.
#25 ·
Your car must have had more room. There was no way, even with the insulation pulled back, that I was getting a tool in there. But all I had to do is, while having the car on jackstands, keep the transmission held up with a jack, unbolt the 2 bolts on the transmission crossmember on one end and really loosen them on the other, then I was able to lower the transmission down like 2 inches which gave me all sorts of room to get my tool in there. I left the 2 bolts really loose just so it wouldn't be a pain to get them back in. It was very simple to do so no one should waste much time trying to get a tool to fit in there. I used a serpentine belt tool that is designed for tight spaces.
#28 ·
My "lift" was 4 12 ton jack stands holding the car 6" off the ground... lol
Did front, rear differentials and the TC all at same time. Was easy peasy. I removed the inner fender on the passenger side to get easier access to the fill tube on the front diff though. Would have been unnecissary on a lift.
