1 - 20 of 21 Posts
2002 DTS
So I had some issues with my dash doing crazy things, things turning off while driving. Discovered that in addition to a new battery, I needed a new engine ground wire. Replaced those both, now I have no power to the dash/ignition. Bolts to the ground wire are both tight and so is the battery. To test I had ground, I used a jumper pack from pos jump point on the front fuse box to the strut bolt, where I've always jumped from. With the broken ground wire, it would not work at all unless I hooked ground to the engine directly. Now it has strong connection and sparks when jumping, but the ignition has no power without the jumper. When the wire was broken, the dash would at least come on and read some voltage. The only thing different between that and this is I have the radiator fans both unhooked so I can make sure everything is good before I put everything back together. Anyone have any idea why the power is not going from the rear battery area to the front?
· Super Moderator
2010 DTS
Wait a minute. You said "To test I had ground, I used a jumper pack from pos jump point on the front fuse box to the strut bolt" and "I hooked ground to the engine directly. Now it has strong connection and sparks when jumping". Unless I am misunderstanding you, it sounds like you grounded (shorted out) the positive side. Kind of like connecting you battery cables backwards. You might start by checking all your fuses and hope that they did their job.
· 2004 Deville base
'05 SRX N*/AWD, Vetts/Birds/Trucks
It sounds like the new ground is not making good contact, when you say a jumper direct to the engine completes the circuit. Shiny metal direct contact is my preference, and a little dielectric grease.
You have power at the front/engine fusebox?
I'm oldskool, I would probably wind out 15ft of wire, go direct from the batt to the front check volt/resistance whichever you like best, disconnect the batt of course don't fry the ohmmeter fuse. Work backwards, check/clean it all.
I check everything cuz I'm OCD, but the ADD messes with follow thru, you find a lot of [email protected] as you go...haha
I also agree with Ranger, a little better explanation maybe...?
I would, in this situation, start with the -negative batt side, to the body under the seat there, on to the front
2002 DTS
Okay, I know it sounds confusing. I was trying to say that with the old ground cable broken, using the jumper the same way I always do would result in no ignition, but dash had power. After placing the new ground wire, I can use the jumper to get the car started from normal locations. However, it does not seem like power from the rear, where the battery is, is reaching to the front, where the fuse box is. Also now the dash gets no power without the jumper pack, with the new ground cable installed.
I bought a new multimeter but I don't really know how to use it, so where do I test and what kind of readings/ranges am I looking for? My guess is should be 12-14v from front fuse box panel to strut bolt ground is the ideal.
· 2004 Deville base
silver-- You have a new MM, check how the ohm/continuity function works. It may even have a 'ringer'/chime built in, many do.
Doing a check this way is almost foolproof, and no power is needed/on, just checking from point to point wiring integrity.
1) check from the negative batt lead to first body point, right there at the corner of the seat. Good-right?
2) get some wire, if you need more length, then check from there to the next findable point, even if it is the engine to body ground strap.
3) you can check the ground strap itself, from the body point to engine, or any other ground point. The idea is ALL ground points have continuity to each other, all the way back to the battery. Guesswork is eliminated.
No matter how new this is to ya, the light will come on in your head pretty quickly, it simply works or doesn't.
The "positive" side of the batt/lead can be done the same, just disconnect the batt first, most MM have a fuse to protect the ohmmeter function from 'voltage', it will blow if you put 'power' to it.
With the newer cars are multiple ground points/sensitive components/hard to find/easy overlooked. Even good mechs get screwed and frustrated with it. I headbang often, I like to hurry up, but these cars are not like a '66 mustang or Deville.
Once you get some "continuity" experience, you might want to try some "resistance" fun and games.
Good Luck, take your time, be sure point to point is solid/good, you will find the gremlin.
2002 DTS
Well guys, I'm not sure if I'm using the meter wrong, or what, but I tried probing battery itself, negative to frame cable, tried alternator to frame newly replaced cable, and I just wasn't getting much of anything or numbers jumped. The important part is that for the hell of it, I jumped it, and drove it around the block. It drove! The dashboard voltmeter reads anywhere from 15-14.5V, barely went below 15 which doesn't sound right since I had a trickle charger on the new battery all night. 14+ volts means alternator is charging, right? Fresh battery should read 12ish on the dash?
· Administrator
A "12 Volt" automotive lead-acid battery should show 12.6 Volts, fully charged and disconnected from anything for a half hour.
That same battery, in the car, should show 12.4 - 12.6 at Key: ON and will allow a system charging voltage of 14 - 15.2 Volts, depending on battery condition. If, after startup, system voltage goes to 14.8 - 15.2 it will stay there for some length of time then, as the battery comes back up to full charge, ramp down to 14.2 to 14.6 Volts and stay there. Amperage, which you cannot see, will vary as the state of the electrical loads changes.
After 2005/2006 the charging specifications are much more dynamic so the DIC will show a much greater voltage spread when driving.
Negative terminal to frame is ground to ground - no voltage will result. Red = positive = +, so + to ground will show system (not necessarily battery) voltage - set to Volts DC.
When all else fails, read the directions .......... https://www.google.com/search?q=how....69i57j0l5.10260j0j8&sourceid=chrome&ie=UTF-8
· Administrator
Not for his 2002 DTS - 13.8+ to about 15.2. His (DTS) car came with the 140 Amp alternator.
Over 15.5 or so he'll see a system voltage high message.
Mine floats between 14.4 - 14.6 all day and night, rural or Interstate. Exide Group 79 lead-acid battery.
2002 DTS
Discussion Starter · #13 ·
Excellent explanation, as always Submariner. So you are saying 15V, while driving/running is normal "depending on battery charge", however, for a week old brand new CAT brand battery that has been fully topped off by a trickle charger nearly nightly since it was bought, 15V seems high, does it not?
My trashed walmart battery ran normally around mid 14's as you'd stated. The CAT brand batteries seem to be the best you can buy here, as he said they have more plates in them. I know they last much better in -40F weather in machinery out here. Otherwise it's a normal lead acid battery as far as I can tell. Same group size I had in there before, vented, just has top and side posts. Any chance 15V is because of a different brand of battery?
· Administrator
Automobile charging systems take into account the average sensed internal battery resistance: a dead battery looks like a short to ground - little or no internal resistance. A fully charged battery has a high internal resistance - that fully charged value can vary depending on battery construction.
That resistance value will vary the charging rate for both voltage and amperage.
What is the running system voltage after 50 - 75 miles on the Interstate ? BatteryMinder notwithstanding.......... My STS sits in the garage with a BatteryMinder connected at all times - 13.2 Volts - and when we disconnect, start up, and head for a 120 mile round trip lunch the DIC voltage is 14.4 - 14.6 each time.
EDIT: DO NOT, ever, use an old ferroresonant "trickle charger" on a battery. The new "smart" chargers are just perfect - but an old ferroresonant hummer will kill a battery in short order if it is left attached and turned on.
https://www.google.com/search?q=aut...rome..69i57.7141j0j8&sourceid=chrome&ie=UTF-8
· Super Moderator
2003 Deville Base
I don't know which alternator mine came with, but after start up I've never seen higher than 14.8
2002 DTS
Discussion Starter · #17 ·
I had the battery and alternator tested at Oreilleys after work, all checked out okay. After driving from work to there to walmart to home, the voltage was almost as low as 14. It's just weird to me it ramps down so much after driving. To me, that seems like it needed a considerable charge.
The trickle charger I use is this one (https://www.amazon.com/Automatic-Trickle-Battery-Charger-1000mA) because it's cheap, "smart", seems to have a lot of protections against stuff, and the quick disconnect is handy. I have it wired through the pass through in the backseat to the battery and out the trunk so I just plug it in. Seems to be very waterproof too. I had it in snow half the winter hanging on a post until it fell down and got buried. Plus it has a variable charge that goes from full charge down to trickle when it's done. Seems to work nicely for the price.
1 - 20 of 21 Posts
