1 - 2 of 2 Posts
1994 Cadillac Sedan DeVille
Hi all,
I have a '94 Sedan Deville with four loose center wheel caps. I thought about getting used one, but I'm sure they will be just as loose as what I have now. Any ideas on how to fix them or where to go to replace them at a discount? Also, I've seen some caps with a black background. Was that an option? Thanks!
Is there any way of bending out the fingers or whatever hold them on a bit to tighten them up?
I have a set of rims that the centre cap has another piece that goes on the end to cover the screws that hold it on. I guess the fingers break easily because some are missing. I put some silicone around the edge when I put them on and that holds them on. The only bad thing is that they're harder to get off when you need to get them off. But if you just used a bit in different areas that should make sure they don't fall off or shake around :)
1 - 2 of 2 Posts
