Cadillac Catera Soon CTS
can some one tell me what is the size of the stock catera injectors how many cc are they??
and is there any info on the ecu pinout ... i am looking to hook up some aftermarket piggyback system and looking for a pinout
None :(
Ok so I have the pin readouts... not sure about injector size. What year Catera is it? This one is for a 99' but the 97-98 are probably different due to non-electronic throttle control.
Code:
Connector C1
Pin   Wire Color- Function
1	BLK/WHT	Throttle Valve Motor (minus)
2	BRN/WHT	H02S 2 Bank 2 Heater Control
3	BRN/BLU	Fuel Injector #3 Driver
4	BRN/GRN	Intake Plenum Switchover Valve Control
5	BRN/RED	EVAP Purge Solenoid Control Valve
6	BRN/GRN	KS Bank 2 Low
7	BRN/GRN	HO2S 2 Bank 2 Ground
8-9	--	Not Used
10	GRY/BLK	CKP Sensor Signal
11	BRN/RED	HO2S 1 Bank 1 Pumping Current
12	BRN/WHT	HO2S 2 Bank 1 Ground
13	--	Not Used
14	GRY/BLK	Ignition Control Cyl #5
15	BLK/YEL	Ignition Control Cyl #3
16	BLK/RED	Ignition Control Cyl #1
17	BRN/YEL	Throttle Valve Motor (plus)
18	BRN/GRY	HO2S 1 Bank 2 Heater Control
19	BRN/YEL	Fuel Injector #1 Driver
20	BRN/BLK	Fuel Injector #5 Driver
21	--	Not Used
22	BRN/WHT	KS Bank 2 Signal
23	BRN/BLU	HO2S 1 Bank 2 Signal
24	WHT	TP Sensor 1 Signal
25	BRN/BLU	ECT Sensor Signal
26	BRN/GRN	Sensor Ground (MAF/IAT, ECT, TP)
27	--	Not Used
28	BRN/BLU	HO2S 1 Bank 1 Signal
29	BRN/GRN	HO2S 1 Bank 2 Pumping Circuit
30	GRY/BLK 	Ignition Control Cyl #6
31	BLK/YEL	Ignition Control Cyl #4
32	BLK/RED	Ignition Control Cyl #2
33	BLK/WHT	Throttle Valve Motor (minus)
34	BRN/WHT	HO2S 2 Bank 1 Heater Control
35	BRN/GRN	Fuel Injector #2 Driver
36	BRN/PPL	Fuel Injector #6 Driver
37	--	Not Used
38	BRN/WHT	KS Bank 2 Signal
39	BRN/BLU	HO2S 2 Bank 2 Signal
40	BRN/BLU	TP Sensor 2 Signal
41	--	Not Used
42	WHT	CMP Sensor Signal
43	BRN/GRN	HO2S 1 Bank1 Pumping Circuit
44	BRN/BLU	HO2S 1 Bank 2 Signal
45-48	--	Not Used
49	BRN/YEL	Throttle Valve Motor (plus)
50	BRN/GRY	HO2S 1 Bank 1 Heater Control
51	BLU/BLK	MAF 5 Volt Reference
52	BRN/RED	Fuel Injector #4 Driver
53	BRN/GRN	Intake Resonance Switchover Valve Control
54	BRN/GRN	KS Bank 1 Low
55	BRN/GRN	HO2S Bank 1 Ground
56	GRY/RED	MAF Signal
57	BRN/BLK	IAT Sensor Signal
58	BLU/BLK	TP Sensor 5 Volt Reference
59	GRY/RED	CKP Reference Low
60	BRN/WHT	HO2S 1 Bank 1 Ground
61	BRN/RED	HO2S 1 Bank 2 Pumping Current
62	BLK	KS 1, KS2, and CKP Sensor Shielded Ground
63-64	--	Not Used
______________________________________________________
Connector C2
Pin     Wire Color - Function
1	BRN/WHT	Cruise Indicator
2-5	--	Not Used
6	BRN/BLU	A/C ON/OFF Signal
7	BLK/RED	APP 2 5 Volt Reference
8	BRN/BLK	APP 1 Signal
9	--	Not Used
10	BLK/BRN	Resume/Decel Signal
11	--	Not Used
12	BRN/GRY	ABS CAN Interface Low
13	BRN/PPL	A/C Relay Control
14	--	Not Used
15	RED	B+
16	RED/BLU	Switched B+
17	--	Not Used
18	BRN/BLK	EVAP Tank Solenoid Control
19-21	--	Not Used
22	BLU/BLK	Fuel Level Input
23	--	Not Used
24	BRN/GRY	APP 1 Reference Ground
25	BRN/GRN	Fuel Tank Pressure Sensor Ground
26	BLK/BRN	Cruise Release Signal
27	BLK/YEL	Stop Lamp Signal
28	--	Not Used
29	BRN/PPL	ABS CAN Interface High
30	RED/BLU	Fuel Pump Relay Control
31	BRN/GRY	Power Relay Control
32	RED/BLU	Switched B+
33	GRY	Filler Cap Lamp
34	BRN/BLU	Secondary Air Pump Solenoid Control
35	GRN	RPM Signal Output
36	--	Not Used
37	BRN/YEL	Fuel Tank Pressure Sensor Signal
38-39	--	Not Used
40	BRN/RED	APP 2 Signal
41	--	Not Used
42	BLK/RED	Cruise ON/OFF Signal
43	BLK/YEL	Cruise Set/Accel Signal
44	BLU/RED	VSS/Theft Deterrent Signal
45	BRN/PPL	Auto Trans CAN Interface High
46	BRN/BLU	MIL Control
47	BRN	Ignition Switch
48	RED/BLU	Switched B+
49-52	--	Not Used
53	BRN/WHT	Serial Data/kw 2000/DLC
54-55	--	Not Used
56	BLK/GRN	APP 1 5 Volt Reference
57	--	Not Used
58	BLK/WHT	A/C Request
59-60	--	Not Used
61	BRN/GRY	Auto Trans CAN Interface Low
62	BRN/GRY	Secondary Air Pump Control
63	BLU/BLK	Fuel Tank Pressure Sensor 5 Volt
64	--	Not Used
yes its a 97 and the injectors should be around 22lb's? still not sure tho not many people have info on these cars
thanks for the pinout should be similar to 97
None :(
Ahaha It is quite different, its all one connector... heres the 97-98 pinout:
As for the injectors I just read that they might be 3 bar or 43 lbs... but Im not 100% on that size.
Code:
1	BRN/WHT	--	HO2S Heater Control (Rear)
2	BRN/BLU	--	IAC Valve Control (Close)
3	BRN/YEL	--	Fuel Injector 1 Control
4	BRN/BLU	--	Fuel Injector 3 Control
5	BRN/BLK	--	Fuel Injector 5 Control
6	BLK	--	ECM Ground
7	BRN/GRN	--	Intake Resonance Switchover Solenoid Valve Control
8	BRN/BLU	--	Malfunction Indicator Lamp (MIL) Control
9- 11	--	--	Not Used
12	BLK/BLU	--	AC Load Signal
13-14	--	--	Not Used
15	BLK/WHT	--	AC Request Signal
16	BLU/RED	--	IAT Sensor Signal
17	BLU/GRN	--	MAF Sensor Signal
18	BRN/BLU	--	HO2S Signal B2S1
19	BRN/BLU	--	HO2S Signal B1S1
20	GRY/RED	--	CKP Sensor Ground
21	BRN/GRN	--	Transmission Torque Reduction Request Circuit
22-25	--	--	Not Used
26	RED/BRN	--	Battery Voltage
27	BRN/GRY	--	Engine Controls Power Relay Control
28	BLK	--	ECM Ground
29	BRN/RED	--	IAC Valve Control (Open)
30	BRN/WHT	--	HO2S Heater Control (Front)
31	BRN/GRN	--	Fuel Injector 2 Control
32	BRN/RED	--	Fuel Injector 4 Control
33	BRN/PPL	--	Fuel Injector 6 Control
34	BLK	--	ECM Ground
35	BRN/GRN	--	Intake Plenum Switchover Solenoid
36	BRN/PPL	--	AC Relay Control
37	WHT	--	AIR Pump Relay Control
38	GRY/RED/BLK--	CMP Sensor Signal
39	RED/BLK	--	MIL Request
40	BRN/WHT	--	Knock Sensor (KS) B2
41-43	--	--	Not Used
44	BRN/BLU	--	Throttle Position (TP) Sensor Signal
45	BRN/LT GRN--       Mass Air Flow (MAF) Sensor Signal Return
46	BRN/GRN	--	HO2S Ground
47	--	--	Not Used
48	GRY	--	Traction Control Torque Reduction Request
49	GRY/BLK	--	Ignition Control (IC) 1-4
50	BLK/YEL	--	Ignition Control (IC) 2-5
51	BLK/RED	--	Ignition Control (IC) 3-6
52	--	--	Not Used
53	BLU/BLK	--	5 Volt Reference
54	RED/BLU	--	Switched Battery Voltage
55	BLK	--	ECM Ground
56	BRN	--	ECM Ignition Feed
57-60	--	--	Not Used
61	BRN/RED	--	EVAP Canister Purge Valve Control
62	PPL	--	AIR Cut-Off Solenoid Valve Control
63	BRN	--	Fuel Pump Relay Control
64	--	--	Not Used
65	BRN/BLK	--	EVAP Canister Vent Valve Control
66-67	--	--	Not Used
68	--	--	Traction Control Input/PWM Interface
69	BLK/RED	--	P/N Signal
70	BRN/WHT	--	Knock Sensor (KS) B1
71	BLU/GRN	--	5 V Reference Ground
72	BRN/YEL	--	EVAP Fuel Tank Pressure Sensor Signal
73	BLU/BLK	--	EVAP Fuel Tank Level Sensor Signal
74	BRN/BLU	--	Engine Coolant Temperature (ECT) Sensor Signal
75	--	--	Not Used
76	BRN/BLU	--	HO2S Signal B2 S2
77	BRN/BLU	--	HO2S Signal B1 S2
78	GRN/WHT	--	CKP Sensor Signal
79	BLU/RED	--	Vehicle Speed/Theft Deterrent Signal
80	GRN	--	Engine Speed Output
81	--	--	Not Used
82	BRN/YEL	--	ECM Data Output
83	GRY	--	Engine Torque Output
84-87	--	--	Not Used
88	BRN/WHT	--	Serial Data
43 LB:| thats great:):):) i am turbo chargin my catera and i am trying to figure out what managment i can use there is couple out there but stull tryin to find the right one there is SMt6 mega squirt aem .. .etc ill keep you up to date
and
thanks jefferyG for your help keep me upto date about those injectors and also where did you find that info in you dont mind shearing
None :(
and
I got the injector info from this site:
http://www.v6calibra.com/tuning/v6_calibra_tuning.htm
The C25XE is basically the same engine family as the Catera (which is an X30XE or SE iirc) and so they may or may not be the exact injectors.
