1 - 10 of 10 Posts
My car just developed a rattle at idle which increases in frequency as the rpm's increase.
It sounds virtually identical to what occured on my Quad-4 Malibu which turned out to be the timing chain tensioner.
Is this a common problem on Catera's and does anyone have any suggestions as to what it could be?
Cateras don't have a chain for timing, they do have timing belt thus they don't do mechanical noise.
Does the check engine light on?
Yup it turned on about 2 day before the noise started.
What is stange is that today the noise was gone.
Any idead as to what it could be?
My 97 catera had some really bad sounds at startup one day. I turned it off and called the tow truck - took it to Cad dealer and they said the tensioner was bad but that it was a recall item - they replaced it free along with a belt and a few other things. Who knows, maybe check for any recalls on yours.
I just called my local cad dealer they say no recalls I also have a 97 Catera new noise coming from timing belt area. How did you find out about recall any help would be appreciated.
the tensioners are a good place to start. had 97 catara tensioner was knocking. bought car cheap previous owner thought it was a rod. start with that tensioner bracket and powersteering pump pully must be removed in order to remove inspection cover off front of motor for more info. [email protected]
1 - 10 of 10 Posts
About this Discussion
7 Participants
lester john
