1 - 20 of 55 Posts
2006 CTS-V Infared, 2013ATS, 2016 ATSV
I have 25000 miles on my 2016 manual coupe. I got it with maybe 20,000 miles. I have been getting a code 0430 cat effy on left side. It happens maybe every month. I took it in and dealership said I needed a new cat. That is not something I would have thought with as low mileage as it is. They also said both rear shocks are leaking.
This certainly a surprise. Anyone else have any cat or shock issues with this low mileage?
Shocks do leak on low mileage cars. The cat is another issue. I don't remember - what's the emissions warranty?
'93 SedanDeville 60 Special
CATs being a smog device by federal law, as shown below
GM has to warranty for 8 years so since they say it is bad let them replace it for free
B. DESIGN AND DEFECT WARRANTY
The Design and Defect Warranty covers repair of emission related parts which become defective during the warranty period. The Design and Defect warranty for model year 1995 and newer light-duty cars and trucks is outlined below:
Design and Defect Warranty Coverage for 1995 and newer light-duty vehicles:
* Emission control and emission related parts are covered for the first 2 years or 24,000 miles of vehicle use; and
* Specified major emission control components are covered for the first 8 years or 80,000 miles of vehicle use.
According to federal law, an emission control or emission related part, or a specified major emission control component, that fails because of a defect in materials or workmanship, must be repaired or replaced by the vehicle manufacturer free of charge as long as the vehicle has not exceeded the warranty time or mileage limitations for the failed part.
Design and Defect Warranty coverage may vary depending on the type of vehicle you have (e.g., heavy-duty trucks, motorcycles or recreational vehicles have different time and mileage requirements).
To determine the length of warranty coverage that applies to your vehicle, look for the emissions warranty information in your owner's manual or warranty booklet. If you own a California vehicle, you may be entitled to additional warranty coverage.
The owner's manual or warranty booklet will also provide you with guidance on the procedures for obtaining warranty coverage. If you have questions about the emissions warranties on your vehicle or need help in filing a warranty claim, contact your local car dealer or the manufacturer's zone or regional representative listed in your owner's
What Emission Control and Emission Related Parts Are Covered by The Design and Defect Warranty?
An emission control part is any part installed with the primary purpose of controlling emissions. An emission related part is any part that has an effect on emissions. Listed below are some examples of parts or systems which fall under these definitions. A more complete list can be found in your owner's manual/warranty booklet.
If any of the parts listed below fail to function or function improperly because of a defect in materials or workmanship, causing your vehicle to exceed federal emission standards, they should be repaired or replaced under the emissions warranty if your vehicle is less than 2 years old and has been driven less than 24,000 miles.
One manufacturer may use more parts than another, so the following list is not complete for all vehicles.
EMISSION CONTROL PARTS
Exhaust Gas Conversion Systems
oxygen sensor thermal reactor
catalytic converter dual-walled exhaust pipe
Exhaust Gas Recirculation System
EGR valve thermal vacuum switch
EGR solenoid EGR spacer plate
EGR backpressure transducer Sensor and switches use to control EGR flow
Evaporative Emission Control System
purge valve fuel filler cap
purge solenoid vapor storage canister and filter
Positive Crankcase Ventilation (PCV) System
PCV valve PCV solenoid
Air Injection System
Air pump diverter, bypass, or gulp valve
reed valve anti-backfire or deceleration valve
Early Fuel Evaporative (EFE) System
EFE valve thermal vacuum switch heat riser valve
Fuel Metering System
electronic control module (unit) or EFI air flow meter, computer command module or mixture control unit, deceleration controls, electronic choke, fuel injectors, fuel injection units and fuel altitude compensator sensor, bars or rails for EFI or TBI systems, mixture settings on sealed fuel mixture control solenoid, diaphragm or other systems, fuel metering components that achieve closed/other feedback control sensors/loop operation switches and valves
Air Induction System
thermostatically controlled air cleaner, air box
Ignition Systems
electronic spark advance timing advance/retard systems,
high energy electronic ignition
Miscellaneous Parts
hoses, gaskets, brackets, clamps and other accessories used in the above systems
EMISSION RELATED PARTS
These are examples of other parts of your vehicle which have a primary purpose other than emissions control but which nevertheless have significant effects on your vehicle's emissions.
If any of these parts fail to function or function improperly, your vehicle's emissions may exceed federal standards. Therefore, when any of the parts of the following systems are defective in materials or workmanship and have failed in a way that would be likely to cause your vehicle's emissions to exceed federal standards, they should be repaired or replaced under the emissions warranty:
Fuel Injection System
fuel distributor
turbocharger intake manifold
Exhaust System
exhaust manifold
Ignition System
distributor spark plugs
ignition wires and coil
Miscellaneous Parts
hoses, gaskets, brackets, clamps, and other accessories used in the above systems.
What Are Specified Major Emission Control Components?
There are three specified major emission control components, covered for the first 8 years or 80,000 miles of vehicle use on 1995 and newer vehicles:
  • Catalytic converters.
  • The electronic emissions control unit or computer (ECU).
  • The onboard emissions diagnostic device or computer (OBD).
Catalytic converters are critical emission control components that have been installed on most cars and trucks manufactured since 1975. Since engines don't burn fuel completely during the combustion process, the exhaust contains a significant amount of harmful pollutants such as carbon monoxide, hydrocarbons, and oxides of nitrogen.
The catalytic converter aids the conversion of these pollutants to less harmful substances such as carbon dioxide, water
vapor, nitrogen, and oxygen before the exhaust is expelled into the environment.
The electronic emissions control unit or computer monitors certain powertrain functions and controls various operating parameters to help the vehicle run efficiently and with the lowest possible emissions. Ignition, transmission function, air injection, exhaust gas recirculation (EGR), engine operating temperature and fuel system parameters are some of the systems monitored and/or controlled by the electronic emissions control unit.
The onboard emissions diagnostic device monitors the operation of a vehicle's emission control system and alerts the driver with a dashboard light when malfunctions occur. The system will record where the problem is occurring and assist automotive technicians in diagnosing and repairing emission control malfunctions.
Since some emission control malfunctions do not have an adverse effect on vehicle performance, they can go undetected by the driver for quite some time.
The onboard diagnostic device will help catch malfunctions early, preventing a significant output of harmful exhaust emissions from your vehicle, and possibly in time to be covered by the emissions control warranty. Often this "device" is part of the electronic control unit mentioned above.
In the future, there may be other parts or components that qualify for this coverage. Check your owner's manual or warranty book for possible additional coverage.
How Long Do the Emissions Warranties Apply to Individual Parts of My Vehicle?
For 1995 and newer model year vehicles, emission control and emission related parts are warranted for the first 2 years or 24,000 miles of vehicle use. Specified major emission-control components are warranted for the first 8 years or 80,000 miles of vehicle use.
Parts with a stated replacement interval, such as, "replace at 15,000 miles or 12 months," are warranted up to the first replacement point only.
How Do I Know Whether I Am Entitled to Coverage Under the Emissions Warranties?
If you or a qualified automotive technician can show that an emission control or emission related component, or a specified major, emission-control component, is defective, the repair or replacement of the part is probably covered under the Design and Defect warranty.
If your vehicle failed a federally approved emissions test and has not exceeded the time and mileage limitations for the Performance warranty, any repairs or adjustments necessary for your vehicle to pass should be covered by the manufacturer if the failure was not caused by improper maintenance or abuse.
When you believe you have identified a defective part, or your vehicle fails an emission test, you should follow the procedures for making a warranty claim as identified by the manufacturer in your owner's manual or warranty
booklet. When taking your vehicle in to have repairs performed under the Performance Warranty, be sure to have with you a copy of the I/M test report as proof of your emissions test failure.
May I Have My Regular Repair Facility Perform Warranty Repairs?
If you plan to have the manufacturer pay for a repair under either of the emissions warranties, you must take the vehicle to a facility authorized by the vehicle manufacturer for repair to give them the opportunity to diagnose and repair it.
Note that if your regular repair facility is not authorized by the vehicle manufacturer, they are not obligated to advise you of parts that are covered under warranty. Before giving your automotive technician the "go ahead" to perform repairs, check your owner's manual/warranty booklet for possible warranty coverage.
Do the Emissions Warranties Apply to Used Vehicles?
Yes. It does not matter if you bought your vehicle new or used from a dealer or anyone else. As long as the vehicle has not exceeded the warranty time or mileage limitations, these warranties apply.
IMPORTANT NOTE:
Before buying a used vehicle, be sure that all of the emission control components as originally installed by the manufacturer are present and functioning properly.
If emission control components are missing or have been tampered with, or the configuration of the exhaust system has been changed, the emissions warranties on this vehicle may be void. In addition, if you live in an area with an I/M program, the vehicle will probably not pass inspection and you will incur the expense of parts or repairs necessary for the vehicle to pass.
Can Any Portion of An Emissions Warranty Repair Be Charged to Me?
If you have valid warranty claim, you cannot be charged for any costs associated with the diagnosis or repair of the problem, including labor charges, parts, or miscellaneous items that are necessary to complete the repair. For example, if a manufacturer agrees to replace a catalytic converter under the emissions warranty, you should not be charged for the diagnosis of the bad converter, or any pipes, brackets, adjustments, or labor needed to complete the replacement.
What Reasons Can the Manufacturer Use to Deny a Warranty Claim?
If your vehicle is within the age and mileage limits for the applicable emissions warranty, the manufacturer can only deny coverage if evidence shows that you have failed to properly maintain and use your vehicle, causing the part or emission test failure. Some examples of misuse and mal maintenance include the following:
* vehicle abuse such as off-road driving or overloading; or
* tampering with emission control parts or systems, including removal or intentional damage of such parts or systems; or
* improper maintenance, including failure to follow maintenance schedules and instructions specified by manufacturer, or use of replacement parts which are not equivalent to the originally installed parts.
What Should I Do If My First Attempt to Obtain Warranty Coverage Is Denied?
If your first attempt to receive emissions warranty coverage is denied, you should do the following:
1) Ask for a detailed explanation, in writing as to why emissions warranty coverage was denied; and
2) Ask for the name(s) of the person(s) involved in the decision to deny coverage, including anyone from the manufacturer's regional or zone office; and
3) Ask for the name(s) of the person(s) with the manufacturer you should contact to appeal the denial of coverage under the emissions warranty.
4) Contact and, if necessary, write to the person mentioned above requesting coverage and giving the basis for your request. Repeat and continue the appeal process until you are satisfied or have exhausted all means of appeal.
What If the Dealer Claims That My Vehicle Can Pass the I/M Test Without Repair?
The law does not require that you fail every I/M test in order to trigger the warranty.
If a valid test shows that you have an emission problem or there is a defective part, you should get it fixed, while your vehicle is still within the warranty period. Otherwise, you might fail a future test because of the same problem and have to pay for the repair yourself.
If you doubt your original test results or the dealer's results or diagnosis, you can always get another opinion from another dealer or your I/M program.
How Can Maintenance Affect My Emission Warranty Coverage?
Performance and the cost of scheduled maintenance are your responsibility. You may either perform scheduled maintenance yourself or have a qualified repair facility perform it for you.
If a part fails as a direct result of your vehicle not being properly maintained or being used in a manner inconsistent with the manufacturer's recommendations, or a part fails as a result of the vehicle being involved in an accident, the manufacturer may not be required to repair or replace the failed part under warranty.
For example, failure to replace the spark plugs at the intervals specified in the maintenance schedule can lead to misfiring and eventual damage to your catalytic converter - a very expensive part to replace.
If the maintenance is not performed properly as recommended, the manufacturer may deny warranty coverage.
To ensure maximum air pollution reduction from the emission control system, as well as to ensure continued warranty coverage, better gas mileage and performance, and longer vehicle life, you should have all maintenance performed as recommended by the manufacturer's schedule. A list of scheduled maintenance for your vehicle can be found in the owner's manual or warranty booklet.
Do I Have to Show Any Maintenance Receipts Before I Can Make an Emissions Warranty Claim?
No. Proof of maintenance is not required in order to obtain coverage under the emissions warranty if an emission control or emission related component, or a specified major emission control component, is found to be defective in materials or workmanship.
However, when it is likely that the lack of proper maintenance has caused the particular part to fail, you may be asked to show that scheduled maintenance was performed.
If you perform scheduled maintenance yourself, you should keep a detailed log of work performed and any receipts for parts purchased to perform the maintenance. In some instances, you may be asked to qualify your ability to perform such maintenance. Vehicles should always be maintained according to manufacturers' specifications.
Are Dealers the Only Persons Allowed to Perform Scheduled Maintenance Recommended by the Manufacturer?
No. Scheduled maintenance may be performed by anyone who has the knowledge and ability to perform the maintenance and repair. You may even maintain the vehicle yourself, as long as the maintenance is
performed according to the manufacturer's instructions provided with the vehicle.
For your protection, before taking your vehicle to a repair facility to have any maintenance performed, check your maintenance booklet and make a list of the scheduled maintenance to be performed at that time.
We suggest that you present this list to your auto technician as opposed to merely asking for a "tune-up" or a "12,000 miles servicing." Your receipt should list all the maintenance performed and should be kept for your records.
If you maintain the vehicle yourself, you should keep receipts for parts and a maintenance log to verify your work.
If I Need Replacement Parts, Must I Use the Vehicle Manufacturer's Parts Only?
No. A manufacturer cannot require the use of any specific brand of parts in the maintenance of your vehicle. However, the manufacturer can require you to use parts that are of equal quality to the original parts.
If I Buy a Used Vehicle, How Do I Know Whether It Has Been Maintained According to The Maintenance Schedule?
The best way to learn whether the vehicle has been maintained according to its schedule is to ask the seller for receipts proving that all of the scheduled maintenance was performed. Having the receipts on hand will provide necessary evidence if the question of maintenance arises when considering repairs under warranty. To
prevent any loss of your vehicle's emission performance, you should continue to follow the maintenance schedule in the owner's manual or warranty booklet.
If the seller does not have the owner's manual, warranty booklet or maintenance schedule, you can obtain them from the manufacturer.
How Will I Know If My Claim Has Been Accepted As Valid?
After you present your vehicle for a Performance Warranty claim, the manufacturer has 30 days to either repair the vehicle or notify you in writing that the claim has been denied. If you are making a Performance Warranty claim and your I/M program imposes a shorter repair deadline, the manufacturer must meet the deadline.
Because of the significance of these deadlines, you should get written verification from the dealer showing that they acknowledge the date by which repairs must be made.
There are no specific requirements for Defect Warranty claims, however, manufacturer responses should be made within a reasonable time period.
What Happens If the Manufacturer Does Not Respond to My Performance Warranty Claim Within the 30-Day Deadline?
You may agree to extend the deadline, or it will be automatically extended if the delay was beyond the control of the manufacturer.
Otherwise, a missed deadline means the manufacturer forfeits the right to deny the claim.
You may then have the repair performed at a facility of your choice, at the manufacturer's expense. (This requirement only applies to Performance Warranty claims.)
What Do I Do If the Manufacturer Will Not Honor What I Believe to Be a Valid Emissions Warranty Claim?
If you believe the manufacturer has not honored a valid claim and your vehicle has not exceeded the time and mileage limitations, you should contact an authorized warranty representative and follow the procedures outlined in your owner's manual or warranty booklet.
If the authorized dealer denies your warranty claim, contact the manufacturer's regional or zone office for further assistance. If you are still not satisfied, follow the appeals procedure outlined in your
Of course, you are entitled to pursue any independent legal actions you consider appropriate to obtain coverage under the emissions warranties. In addition, the Environmental Protection Agency (EPA) is authorized to investigate the failure of manufacturers to comply with the terms of these warranties.
If you have followed the manufacturer's procedures (including those for appeals) for making a warranty claim as set out in your owner's manual or warranty booklet, have received a written denial and you are not satisfied with the manufacturer's determination, you may submit a letter to EPA at the following address.
It should provide details of the situation including the basis for the claim, a copy of the written denial, copies of your letters to the manufacturers, and copies of any receipts for emission control parts and repairs you have paid for:
U.S. Environmental Protection Agency
Vehicle Programs & Compliance Division (6405J)
Attn: Warranty Complaints
401 M Street, SW
Washington, DC 20460
Other sources of assistance may be your local or State consumer protection agency or office of the Attorney General. You also should be aware that low-cost or free legal assistance may be available through a local legal aid office, the State bar association, or a law school clinic staffed by law students.
In Summary
If an emission control or emission related part, or a specified major emission control component is defective, or if your vehicle fails an I/M test, and your vehicle is within the time and mileage limitations for emissions warranty coverage:
* present a warranty claim to an authorized warranty representative.
If your warranty claim is denied:
  • Ask for the reason for denial, in writing.
  • Follow the appeal procedures in your owner's manual. If you are not satisfied with the manufacturer's decision:
  • Contact the EPA, which will investigate the denial of a valid emissions warranty complaint.
Keep This With Your Vehicle for Future Reference.
Could be something easy like a bad O2 sensor, a drippy or sticky fuel injector on the driver's side bank causing it to run rich or lean misfire which can hurt the cat over time, etc. Even something as simple as a bad spark plug or coil pack on the driver's side could cause misfire issues which may lead to cat issues, and these cars are somewhat hard on plugs and coil packs.
You might also have a leaky turbo seal on the driver's side, or worse yet, the intake manifold debris problem which hurt the bores, pistons, and rings-- either of these will put oil and oil smoke through the cat which can kill the cat prematurely. Any oil smoke on a cold start after sitting? How's the oil consumption between changes?
I'd certainly want it diagnosed before throwing parts at it. Easy to check fuel trims and do a cylinder balance test to check for a bank 2 injector issue, check secondary O2 sensor activity, check spark plugs for electrode condition and carbon tracking, etc, before just throwing a new cat at it.
Hopefully it's something simple and not a symptom of a larger issue.
I notice your mileage is low. What are your driving habits? Short trips?
Sent from my SM-G988U using Tapatalk
2008 Escalade ESV 2WD 6.2
There are a few people selling their old OEM cats on FB groups...
Do you need emissions testing? Now's a great time to upgrade to catless DPs and a tune. You'll never regret it.
You realize of course that it is Federal offense to remove CAT's with $10,000 fine. I know. chump change right?
It is common for the shocks to be slightly seeping but only when fluid is reaching the ground will the dealer replace the shock.
2016 ATS-V sedan 6 speed manual
OT but related:
Not a fan of disabling emission controls. The emissions warranty is sufficient but, as stated before, figuring out if something else is causing the problem gets rid of future issues.
OT but related:
Yep, I've mentioned in other threads that the CA smog machines are going to start checking for stock tunes. That's going to make headaches for a lot of people with modded cars that previously passed the plug in portion of the smog test. And just wait, I bet a few other states adopt the same process...
It's really going to make it a pain in the ass for people that have normally "invisible" hard parts that sneak by the visual part of a smog test but won't play nice with the stock tune, they're going to have to physically swap parts every 2 years for smog testing so the stock tune will work and set the monitors.
That's a big reason I haven't done the high volume fuel pump plunger for an E85 tune, I hear it will sometimes throw codes for high rail pressure with the stock tune as the hpfp duty cycle to maintain target rail pressure is well out of normal ranges with the high volume plunger. I do not want to be swapping a fuel pump every 2 years for smog.
Either that or I buy a piece of property 40 miles east in the next county over where they don't do biennial smog testing and register the car there... Lol.
OP, keep us updated what they find.
Discussion Starter · #11 ·
Yes, short trips. Mostly back and forth 5 miles morning and 5 miles home again. I have been thinking I need to get the car out on the highway for a couple hours to warm things up better. I only get the check engine light every couple of weeks maybe. So I am now thinking that may be the issue.
I am in Canada. All the emission warranty stuff does not appear here. The dealer said no warranty. I bought the car from copart and fixed the burn issue so I'm well aware of no warranty anyway.
The shocks are something I would not have checked. (I just replaced the shocks and stuts on my 2006 CTSV with 100000 miles, nothing was leaking but the shocks were shot.)
I would never remove the cats. Heck I installed cats on my 97 3 series BMW with LS swap.
Just go 🐈less
Short tripping the car 5 miles is hard on it from a warm up and condensation buildup standpoint in the crankcase, transmission, and diff as 5 miles is not enough distance or time for things to get hot enough for long enough to cook off any trapped moisture... but it should not have hurt the cats. The ECM does have a cat lightoff mode on cold starts that alters the fuel injection pulses and cam timing to bring the cats up to effective temp rapidly to reduce cold start emissions. Still, it wouldn't be a bad idea to take the car on a longer trip to really warm everything up (and maybe beat on it some) to get things good and warm.
You didn't say, any puffs of oil smoke out the exhaust on a cold start after it's been sitting 24 or more hours? How's the oil consumption between oil changes?
I'd still plug in and check the stuff you can with a scanner first on the affected bank-- primary & secondary O2 sensor readings and activity, short term & long term fuel trims, and run a cylinder balance test to check for a possible injector issue. If those check out then pull coil packs and plugs for inspection. If that checks out I'd be tempted to swap the secondary O2 sensors from side to side (provided the wire lengths on the sensors aren't side specific) and see if the code stays on bank 2 or if it moves to bank 1. If it switches banks, it's a bad secondary O2 sensor.
If you do end up needing a cat, I'd certainly get a used one off the forums or facebook groups for a reasonable price before I paid $730 for a new one... or if you don't have emissions testing up there you could easily disable the secondary O2 sensors in a tune or put extenders on the rear O2 sensors and not worry about catalyst efficiency codes again. But before I did any of that I would want to confirm it's actually just a bad cat and that the bad cat isn't a symptom of another problem with the engine.
Finally... I remember you posting you bought your car from copart with some fire damage up front... you mentioned in an older thread that you replaced the engine harness, but did you replace the ECM too? Since you've been in there and had things apart, you might want to check pin fits on all the pins relating to the bank 2 secondary O2 sensor... but I wouldn't tear into the ECM and engine harness until I first checked all the easier things I mentioned above.
2017 ATS-V 6MT CWT Sedan, Tuned 2016 Explorer TT
Not everyone has an interest in HP tuners, removing federally mandated emissions control equipment and generally modifying the car. I know, its hard to believe.
2016 ATS-V, 1969 Cougar XR7 Convertible, 1970 GTO, 1970 Torino GT, 2006 XLR
I wholeheartedly agree with Slicky. In case you people have not noticed we have a real global warming climate change problem going on in spite of what the climate denyers say. Engineers spend considerable time trying to make cars perform well and be easy on the environment. I know I will probably get some blow back on this comment and probably be labeled a tree huger. Oh well...Wake up, grow up and take care of the planet, it is the only one we have!
So if you believe man is the main contributor to climate change, how can you justify owning an ATS-V?
2020 XT5, 2017 ATS-V M6,1968 Corvair, 1974 Corvette, 2003 HD Road King
While it is far from the most economical car available, it is still way better than most performance cars. If I really try, I can eek out almost 30 MPG
This is the exact same type of ridiculous logic that I would expect from people who share Jim's philosophy. I own the V but I am driving it within its engineered design limits and not modifying it to make its impact on the environment worse than it has to be. If you need convincing that human made climate change is not human induced, check out what is happening with all the out of control wildfires in California, rising sea level etc. Probably not long before Florida and other coastal areas are underwater or experience more flooding going forward. This is all I am going to say about this because it isn't the forum for it and I am going to just ignore irratonal, illogical arguments about the concept of human's assault on the planet.
1 - 20 of 55 Posts
