1 - 19 of 19 Posts
08 CTS DI
Cassette Tapes, Record albums, Transferring to USB & CD for modern Auto Audio systems
I have a lot of music and backing tracks on cassette tapes and albums collected over the years that I've wanted for some time to backup on my PC and transfer to CD and USB. Since the music predates CD, nearly all of it was not reissued on CD. While looking at conversion equipment, I stumbled across the youtube video below that shows how to do this on my existing computer.
The video states to use Win7, but that's probably because of the time it was posted, right around the Win8 appearance. I tried it with a Win7 PC that was upgraded to Win10 and it worked exceptionally well in my opinion. I also used an old 64 MB flash drive to test a transferred song in the car.
Not only did it work perfectly, the use of a small volume flash drive resulted in a quicker start to play.
Another benefit from this process is that the voice recorder application saves the song in M4A format, which is better than MP3, but still compressed. There is essential editing capability in the program also.
The appropriate connectors are readily available to accomplish this, in my case an RCA to 3.5 mm stereo cable, for a direct link between the components and the PC. For a more customized sound, it is best to run the components through a receiver, otherwise a direct link will maintain the original sound characteristics of the album being recorded.
It takes a little more time than the length of the album to complete in one sitting, but you get to enjoy some really good music that you may not have heard in years, to decades along the way and you can take as much time as you want to complete the task.
My initial attempts before seeing this video failed because of the same mistake the author of the video is making. He is using the microphone jack, that may work in Win7 (would not work on my Win8 system to 10 laptop), but it is incorrect. The microphone is apparently mono and the process needs stereo, which is the BLUE access point for "Line in".
So use the 3.5 mm input identified by the Blue square. You will then need to go into audio settings and select line in as the primary input source and deselect microphone. So far I have completed one cassette album and just need to plug it in the car and play it through. Cassette tapes deteriorate over time and I caught this one early in the process.
I hope this helps someone. I caught a great sale on some backing tracks/play along music over the Christmas Holidays for my horn, the catch was that it was all on cassette tapes, which is no fun having to rewind in order to start from the beginning, so this discovery is a real treat for me.
https://www.youtube.com/watch?v=wfupyQRN5Zk
2011 CTS coupe 1989 Allante
Re: Cassette Tapes, Record albums, Transferring to USB & CD for modern Auto Audio sys
Just a similar experience but for various reasons I have added hands free telephony to all of my cars. Along with this I stream music and GPS audio through the sound system. In most cases I added a magnetic mount close to the driver so I can answer the phone with a finger flick. The cell phone is also able to index the 500+ albums by album, artist, and song as well as create playlists.
I use this method because I have several cars off different capabilities and want to use the same phone in each. This is possible and usually for under $50/car. The best system I have seen so far is the Chrysler Uconnect in my Jeep. However is can all be duplicated in any car with an FM receiver. (What I use in my '70 Pontiac)
Music I can rip from several sources into either .mp3 or .wma. I keep the main library on my Win 10 desktop. Have been finding new an better ways since 2012.
2009 CTS4 Premium & 2021 Blazer 2LT
Basically all you need is an RCA-to-miniDIN 3.5mm stereo adapter. These are readily and cheaply available. Of course you also need a functioning player for whatever source medium you're copying from, that has the RCA output. The time consuming part is digitally recording the analog audio input and then separating and identifying the tracks.
08 CTS DI
Discussion Starter · #4 ·
I record the tracks one at a time so there's no separating involved. The recording app allows the beginning and end point of the track to be set after it is recorded after which I simply crop the excess off with the click of a button and save it. The average song is about 5 minutes long, so I can save a song or two per day and complete one album per week until I'm done. For someone who has a lot of time on their hands, they can complete several a day spending about an hour on each album. It takes time, but it is spent actively listening to something I enjoy, which I consider making good use of time.
Sorry but am waaay too lazy for that. My S5 is about 4 years out of date but has what I need: a 64 GB micro SD for the 500+ albums I bought over the years and a touchscreen. (Main library is on my PC.)
Display advertising Movie Advertising Poster Technology
ps can transcribe from vinyl, reel to reel, 8 track, cassette, CD, and DVD
2013 XTS4 Platinum '91 Caprice Wagon '15 Impala LTZ (wife's)
For my vinyl record albums and 45's, I used a turntable with a usb plug output and Audacity free software to put my music on my desktop itunes and then my ipod.
https://www.audacityteam.org/
Spent some time last winter listening to and transferring, editing, naming, sorting and adding album cover art to 100+ record albums.
It was gratifying and helped pass the time during some miserable winter weather.
I have an AR turntable and a preamp used for Vinyl & works very well. Also component 8-track, cassette, and reel-to-reel equipment (some I have had since a 1969 tour of SEA). When you live in the same house for 35 years you tend to acquire things.
2013 Black Diamond CTS4 Premium Coupe (sold-09 CTS4 DI Black Raven/Ebony)
08 CTS DI
Discussion Starter · #9 ·
I have Band In A Box which is a bit more sophisticated, but I like the immediate simplicity Audacity appears to have. Thanks for that link.
Interesting how folks are transferring from vinyl to digital, yet some artists are selling vinyl again.
https://www.amazon.com/Spirits-Fire/dp/B07KH8796V/ref=tmm_vnl_swatch_0?_encoding=UTF8&qid=&sr=
My purpose as far as vinyl goes is because I have backing tracks on vinyl that I use for my horn and when practicing (woodshedding) a tune, particularly a challenging one like Bebop and Salt Peanuts as played by Ernie Watts and Joshua Redman respectively, it's easier to click a button to start over from the beginning, than rewind a tape, or pinpoint a stylus, not to mention the ability to isolate a specific section anywhere in the track to focus on. The tapes are a different matter, they degrade over time and as I mentioned earlier, a large portion of what I have was not reissued on CD. Digitizing would also be necessary to play my vinly music in the car. I'm converting purely out of necessity. I have read about the unique qualities of vinyl relative to CD though so I'm not going to throw my albums away after I finish.
And there are some who swear by 6550s. OTOH being 70-80 db down in the highs, almost anything with sufficient volume and clarity sounds good to me. Also being able to put 500+ albums in something the size of my fingernail with sort, search, and index capability on a touchscream is quite compelling. Particularly when I have to choose which car to drive (good chance I'll have an XLR in the near future).
Do have much vinyl stacked vertically in many cartons but frankly cannot tell a V15 type 2 from a high quality mpg (with unlimited space I always rip at the highest quality). These are the good old daze.
2014 CTS4 Sport Wagon*2016 CTS V-Sport Premium
that Shure is an interesting comparison...
Bill
your V15 type ll cart is made by Shure isn't it???...my poor attempt
Bill
08 CTS DI
Discussion Starter · #15 ·
Yes, I got it, just did not comment on it. For those who know who Sidney Shure was it was unnecessary. For those who don't, well they probably do not know what 33 1/3 is either.
Depends on your "angle" of approach. The name is most notable to me in reference to microphones, but since that's not what we're talking about, I didn't catch silversports' bold type hint until after his follow up question.
it was my fault for engaging and then assuming the comment made after my remark was directed to me...
https://www.bing.com/videos/search?...B53D3883FE42A4108ACDB53D3883FE42A41&FORM=VIRE
Bill
08 CTS DI
Discussion Starter · #18 ·
1 - 19 of 19 Posts
