I have a beautiful 89 Fleetwood that was driving strong, it only has 89k miles on it. All of a sudden, she starts up fine...I have trouble getting her moving...when I do...she doesnt like it when I hit the brakes or stop at red lights. She fusses when I hit the gas. I took her to a shop, they did a diagnostic test, she came up clear. They tested the computer and nothing happened. They said it was either the carb or ignition system, they couldnt guarantee either or and if I wanted to have it checked out, it would cost me a lot. Does anyone know if the Fleetwood is prone to any problem like this? I do not want to get rid of her, but I might have to..please help. [email protected]
2005 CTS-V, 1994 Infiniti Q45
Welcome!! Thanks for siging up!!! :wave:
I dont really know, but I can guess it could be a missing cylinder..... Either spark plug or distributor....... I couldnt tell you for sure, someone will chime in for more info......
Unfortunately, the discription is rather vague and there could be many things giving you the problem.
It could be as simple as a vacuum leak caused by a cracked vacuum line, or as complicated as a dropped cylinder from lack of compression. One way to find out if it's a lean condition is to take a shop rag and very slowly cover up the top of the carb (primaries). If the engine smooths out as you start to cut off air through the carb, it's a lean condition like a vacuum leak etc. If it just gets worse and stalls as you do it, then I'd look for an ignition issue. It could also be a very RICH condition. in this case, give it a vacuum leak and see if it runs better. This would indicate something like a stuck float or similar problem.
