2001 Deville base
2001 Base Deville, 149,000 miles
I was in a parking lot and tried to crank the car. The key moved freely in the cylinder. Nothing happened and there were no clicking noises.
No OBD-II codes were found. I checked the battery voltage from the dash panel and it read 11.4 V or so. Then I tried to crank it again, and it cranked right up.
The battery does seem to get recharged because the dash reads 14 V or so.
This has been happening about once every 20 tries or so, and it seems to be getting more common.
I have no clue what is going on. Zip. Thanks.
2004 Deville
2004 Deville, Silver, Gone, but not forgotten, 1972 Eldorado, 1974 eldorado, 1975 CDV
maybe a bad neutral safety switch ...
04 Deville, 11 DTS Premium, 00 Deville (sold), 02 Deville (sold)
11.4 volts with the engine not running is a dead battery.
575327
The 14 volts with the car running would indicate the alternator is working. Most of the chain auto parts stores will test your battery and alternator for free.
2001 Deville base
It started fine when I saw 11.4 v on the dash. A multimeter reading at home showed 12.4 V. I don't know how accurate the dash panel reading is. If it happens again I'll check for a battery drain. Mmmm..
